Lower 4 Bits?
I am trying to "mask" or "isolate" the lower 4 bits of a byte, and having trouble.I tried using the example on page 26 of the PBP manual:
SecOnes var byte 'should be NIBBLE?
SecOnes = Seconds & $0f
This gives a "Bad Expression" error when compiling. Can someone help, please?
Thank you
Try-
Seconds var byte
Or-
SecOnes = SecOnes & $0f
I forgot to add that there already is a SECONDS variable, and it still has the error. Why does it say $0f ???
This should not return any errors.
SecOnes var byte
Seconds var byte
Of course the result will be unknown since none of the variables are initialized, but it
definitely should not return an error.
Because a value of $0F (%00001111) ANDed with another 8-bit value will return all
0's in the upper 4-bits of the result MASKing the upper 4-bits out.
Thank you, Bruce for the explanation. I now understand how it works. I failed to explain that I'm trying to "add-on" (within the Main portion of my program) to DT's Elapsed_INT-18. That's why I said the Seconds variable was already declared. So, when I declare it again, I get the redefinition error. I'll try adding the SecOnes stuff to HIS program!
