Hi.
I cannot write a new value to a mcp41010 SPI Digital Potentiometer. What I'm trying to do is
UpdPotVal goes from 0 to 255Code:WriteSPI:
CS = 0 ' Enable serial EEPROM
Shiftout SI, SCK, MSBFIRST, [$06] ' Send write enable command
CS = 1 ' Disable to execute command
CS = 0 ' Enable
Shiftout SI, SCK, MSBFIRST, [$02, 0, 0, UpdPotVal] ' Send address and data
CS = 1 ' Disable
Can somebody please tell me what I am doing wrong. Here is a C code that does the same thing in case somebody knows how to make use of it!
RegardsCode:#define CS PIN_B4
#define SCLK PIN_B2
#define SI PIN_B1
set_pot (int data) {
BYTE i;
BYTE cmd[2];
cmd[0] = data;
cmd[1] = 0x11;
output_low(SCLK);
output_low(CS);
for(i=1;i<=16;++i) {
output_bit(SI, shift_left(cmd,2,0));
output_high(SCLK);
output_low(SCLK);
output_high(CS);
shutdown_pot () {
BYTE i;
BYTE cmd[2];
cmd[0] = 0;
cmd[1] = 0x21;
output_low(SCLK);
output_low(CS);
output_high(SCLK);
output_low(SCLK);
output_high(CS);
