Switch Polling vs Interrupts
Using 16F876-04/SP
Hi
I am a embedded programming newbie and need some advice.
I’m in process of making a "simon" type game: a game where an led array displays a random lighting sequence and the player tries mimicking it via button inputs.
The rules of my game differ slightly from the standard simon, it uses more led’s, the leds’ are bi-colored, and the user is required to mimic display timing which unlike simon is non-uniform.
Switch polling question:
the ability to display led’s flashing on/off green and on/off red is integral to game play and therefore I need to be able to use the pause command several times within my program.
My concern is that user input (momentary switch input) will be missed because it occurs during a pause.
* Does anyone have advice on how to avoid switch poll misses?
Interrupt question:
I assume the 16F876 has at least 3 interruptible pins which would allow me to keypad my switches in such a way to trip an interrupt whenever a button is pressed.
* Are interrupts fast?
Timing is critical in my application.
Will having interrupts going off every time a user hits a switch cause slowdowns?
I might want to use TMR to capture player reaction times. Will interrupts stop or interfere with the clock?
