Serial and Port B interrupt
I am using PIC16F877 and planning to have serial cable connect to PIC.
PIC will detect the input RB0, which will trigger an asm int to increase a counter variable.
I plan to use SERIN, but then if RB.0 always got interrupt, then SERIN will never get to execute when PC send a command to PIC. In this case, this serial command is lost.
How do I use serial HW interrupt, so it has a higher priority than asm RB.0 INT?
Note that RB.0 will have an interrupt every 10us, and a counter variable is incremented in this ISR. is this possible with a 20MHz crystal? Each asm instruction cycle is 0.2us right?
