:mad:
pleas I need help.
I have corswork
MICROCONTROLLER 8051
You are required to:
• Define all the values of the registers required so that you program the 8051’s UART to work
in mode 1 at 1200bps (assuming the clock frequency of the 8051 is 16MHz).
• Explain the process needed to receive data through the serial port and use it to light a desired
pattern in the LED dis
please help my by assmbly code.
