what do i do wrong?
i'm trying to do a 1750Hz tone générator on 12c508a and it doesn't work so i reduce the code and test it on 12f683 (with the right fuse!) and it run ok so i test it on 12f508 it doesn't run too.
here are the two test code, i don't understand what i'm doing wrong.
code for 12f508 that doesn't work
@ device pic12F508, INTRC_OSC, MCLR_OFF,WDT_OFF,PROTECT_OFF
GPIO = %00000000 ' toutes les sorties = low
'CMCON0 = 7 ' Comparateur en mode 'comparator off'
TRISIO = %00001000 ' GP0 à GP5 en sortie sauf GP3
'ANSEL = %00000000 ' entrée analogique off
'WPU = %00000000 ' Pull-ups off
OPTION_REG.6 = 0 ' disable internal pull-ups
' Déclaration des variables
' Déclaration des E/S
SORTIE var gpio.2
output sortie
' Initialisation
low sortie
' Début de programme
DEBUT:
high sortie
pauseus 286
low sortie
pauseus 286
goto debut
code for 12f683 that work well
@ device pic12f683, fcmen_off, ieso_off, intrc_osc, wdt_off
@ device pic12f683, pwrt_on, mclr_off, protect_off
OPTION_REG.7 = 1 ' Disable internal pull-ups
SORTIE var gpio.2
' Initialisation
low sortie
DEBUT:
high sortie
pauseus 286
low sortie
pauseus 286
goto debut
i use 'pauseus' instead of 'freqout' because 'freqout' doesn't work on 12Cxx
can someone help me?
Add this line at the top of your 12F508 code, before the TRIS line.
it work fine now!
thanks a lot
merci beaucoup et bonjour de france
