thank you so much for your time. Your code looks impressive.
There are lots of bits that I don't understand yet but it's great because I like to learn.
Will study your code...
ABS reading times 2.5uV divided by 100. Is current in uAmps.
ABS readings time 25 is current in nA. If I didn't make some mistake...
EDIT: max current is 0.84mA...
I think your resistor is too...
trying to capture a serial stream with a bit-banged routine triggered from an isr is difficult to make reliable far better to use the eusart module.
to reset rbcif flag you...
Re: ina226 code for current with r100 resistor
What value is appropriate for the CALIBRATION number in the settings?
raywmson Today, 11:38
