You can play with the place of the dot, and minus sign. Pretty easy to figure out how the code works. So no need to get into explanation much.
__config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_ON & _BOREN_ON & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
__config _CONFIG2, _WRT_OFF & _STVREN_OFF & _BORV_LO & _LPBOR_ON & _LVP_OFF
clear
define OSC 4
OSCCON = $68
TRISA = 0;
TRISB = 0;
TRISC = 0;
ANSELA = 0;
ANSELB = 0;
ANSELC = 0;
ADCON0 = 0;
ADCON1 = 0;
ADCON2 = 0;
LATA = 0;
PORTA = 0;
LATB = 0;
PORTB = 0;
LATC = 0;
PORTC = 0;
FVRCON = 0;
T2CON = 0;
CM1CON0 = 0;
CM1CON1 = 0;
DEFAULT_BIT_DELAY con 100
TM1637_I2C_COMM1 con $40
TM1637_I2C_COMM2 con $C0
TM1637_I2C_COMM3 con $80
LEDPIN var PORTC.3
TM1637_CLK var PORTA.0
TM1637_DIO var PORTA.1
TM1637_CLK_DIR var TRISA.0
TM1637_DIO_DIR var TRISA.1
Number var word
m_brightness var byte
brightness con 7
dispon con 1
WriteByte var byte
'When these two values change, you need to take care of the dot and minus sign behaviour.
pos con 0 ' Shifts position of the number on display
length con 4 ' how many digits to show on display
' just variables.
k var byte
i var byte
tempbits var byte
tempbits = 0
dot_yesno var tempbits.0 ' want to show dot?
dot_digitno var byte ' on which digit to show the dot?
minus_yesno var tempbits.1 ' want to show minus sign?
minus_digitno var byte ' on which digit to show the minus sign?
dig2_onoff var tempbits.2 ' depending on the minus sign is either yes or no,
dig3_onoff var tempbits.3 '... turn the left most digits off.
minusSegments con $40 ' did you want a minus sign on display?
digitToSegment var byte(16) ' Seven segment LED bits corresponding to the number digit.
digitToSegment[0] = $3F '// 0
digitToSegment[1] = $06 '// 1
digitToSegment[2] = $5B '// 2
digitToSegment[3] = $4F '// 3
digitToSegment[4] = $66 '// 4
digitToSegment[5] = $6D '// 5
digitToSegment[6] = $7D '// 6
digitToSegment[7] = $07 '// 7
digitToSegment[8] = $7F '// 8
digitToSegment[9] = $6F '// 9
digitToSegment[10] = $77 '// A ' can also display some letters.
digitToSegment[11] = $7C '// b
digitToSegment[12] = $39 '// C
digitToSegment[13] = $5E '// d
digitToSegment[14] = $79 '// E
digitToSegment[15] = $71 '// F
Begin:
gosub startTM
gosub stopTM
gosub TM1637Display
gosub setBrightness ' brightness con 7, 7 is max.
minus_yesno = 0
minus_digitno = 3 ' show minus sign on digit 3.
dot_yesno = 0 ' show no dot for now.
dot_digitno = 2
number = 456;
gosub setSegments ' call this once.
Start:
PAUSE 10
goto start
setSegments:
'Write COMM1
gosub startTM
WriteByte = TM1637_I2C_COMM1
gosub writeBytes
gosub stoptm
'Write COMM2 + first digit address
gosub starttm
WriteByte = TM1637_I2C_COMM2 + (pos & $03)
gosub writeBytes
dig2_onoff = 1
dig2_onoff = 1
' Write the data bytes
for k = length-1 to 0 step -1
WriteByte = digitToSegment[number dig k]
if dot_yesno = 1 && k = dot_digitno then WriteByte.7 = 1
if minus_yesno then
if k = minus_digitno then WriteByte = minusSegments
if k > minus_digitno then WriteByte = 0 ' turn of digits after minus sign.
gosub writeBytes
next k
gosub stoptm
'Write COMM3 + brightness
gosub starttm
WriteByte = TM1637_I2C_COMM3 + (m_brightness & $0f)
gosub writeBytes
gosub stoptm
startTM:
TM1637_DIO_DIR = 0;
PAUSEUS DEFAULT_BIT_DELAY
stopTM:
TM1637_DIO_DIR = 0
TM1637_CLK_DIR = 1
TM1637_DIO_DIR = 1
writeBytes:
' 8 Data Bits
for i = 0 to 7
'CLK low
TM1637_CLK_DIR = 0;
' Set or Clear databit
TM1637_DIO_DIR = WriteByte.0[i];
'CLK high
TM1637_CLK_DIR = 1;
next i
' CLK to zero
TM1637_CLK_DIR = 0
TM1637_DIO_DIR = 1
TM1637_CLK_DIR = 1
if TM1637_DIO == 0 then TM1637_DIO_DIR = 0
TM1637_CLK_DIR = 0;
TM1637Display:
' Set the pin direction and default value.
' Both pins are set as inputs, allowing the pull-up resistors to pull them up
TM1637_CLK_DIR = 1;
TM1637_DIO_DIR = 1;
TM1637_CLK_DIR = 0;
TM1637_DIO_DIR = 0;
TM1637_CLK = 0;
TM1637_DIO = 0;
setBrightness:
if dispon then
m_brightness = (brightness & 7 ) | 8
m_brightness = (brightness & 7)
