160bytes @ 50Hz is only 64kbits/s (average). Even SHIFTOUT should be able to handle that.
Running the SPI or MSSP module at a moderate 1Mbit/s will transfer those 160bytes in less than 2ms leaving...
I think the bottleneck will be the serial interface speed (SPI) which is normally used in small OLEDs. I could not find this display WS0010B on searching for it. Unless the PIC supports a SPI DMA...
Hello.
I'm doing a graphic project, where content of WS0010b OLED display will be updated really fast, 50fps at least.
The framebuffer size is 160 bytes. Will PBPs arraywrite/arrayread operations...
When the batch file is launched with admin rights (I made a shortcut file to my batch to be able to launch it with admin rights), all HEX, ASM, etc files are not...
Re: 18F2580 with strange behaviour when using Hserin and RX interrupt
Hi Richard,
PaulMaker Yesterday, 13:51you are correct (as always)!
I thought we had to choose internal insteal of primary since it's set to an internal osc.
