Enjoy !
; SCROLLING THERMOMETER
; FINAL VERSION
; By NICULESCU DAN
; SEPTEMBER, 13, 2011
; .oooO
; ( ) Oooo.
; \_) ) /
; (_/
@ DEVICE pic16F628A, intOSC_osc_noclkout, WDT_OFF, PWRT_OFF, BOD_OFF, MCLR_off
define osc 4
INTCON = 0
TRISA = 000000 ' CATODES TO PORTA
TRISB = 000000 ' ANODES TO PORTB
CMCON = 7
DQ var PortB.7
eeprom 0, [100001,111010,110110,101110,100001] '0 Note : 1 = led OFF ; 0 = led ON
eeprom 5, [111111,111101,000000,111111,111111] '1
eeprom 10,[111101,111110,101110,110110,111001] '2
eeprom 15,[111101,111110,110110,110110,101001] '3
eeprom 20,[100111,101011,101101,000000,101111] '4
eeprom 25,[111000,111010,111010,111010,100110] '5
eeprom 30,[100001,110110,110110,110110,101101] '6
eeprom 35,[111110,001110,110110,111010,111100] '7
eeprom 40,[001001,110110,110110,110110,001001] '8
eeprom 45,[111001,110110,110110,110110,001001] '9
counter var byte
scan var byte
scroll var byte
leddata var byte[36] 'Column Data for display 36 columns
temperature var Word 'reading from sensor
Sign var BIT
tempA var byte 'Stores First digit (High)
tempB var byte 'stores Second digit (Mid)
tempC var byte 'stores Third digit (low)
n var byte
DS18B20_12bit CON 111111
START:
CLEAR
' Init Sensor
OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_12bit]
OWOut DQ, 1, [$CC, $48]
OWOut DQ, 1, [$CC, $B8]
OWOut DQ, 1, [$CC, $BE]
Pause 50
OWIn DQ, 2, [temperature.byte0, temperature.byte1]
Pause 50
OWOut DQ, 1, [$CC, $44]
Sign = temperature.15
temperature= ABS(temperature)
temperature=((temperature >> 4)*100) + ((temperature & $F) * 100 >> 4)
if sign then temperature= -temperature
tempA = temperature DIG 3
tempB = temperature DIG 2
tempC = temperature DIG 1
if tempA = 0 then
FOR counter = 0 TO 4
leddata [counter+8] = 111111
next
for counter = 0 to 4
READ tempA*5+counter,leddata [counter+8] 'stores 1st digit in leddata locations 8,9,10,11,12
NEXT
READ tempB*5+counter,leddata [counter+14] 'stores 2nd digit in leddata locations 14,15,16,17,18
NEXT
READ tempC*5+counter,leddata [counter+23] 'stores 3rd digit in leddata locations 23,24,25,26,27
NEXT
'leddata locations 0-7 are blank so that data scrolls onto display
'leddata locations 8-12 1st digit (leading digit)
'leddata location 13 blank column between digits
'leddata locations 14-18 2nd digit
'leddata location 19 blank column between digits
'leddata locations 20 & 21 Decimal Point
'leddata locations 23 - 27 3rd digit (last digit)
'leddata locations 28 blank column between digits
'leddata locations 29 - 34 Degrees C symbol
'leddata location 35 is a blank column at end to clear display as it scrolls
for n=0 to 7
leddata [n] = 111111
next n
leddata [13] = 111111
leddata [19] = 111111
leddata [20] = 111111 ' DECIMAL POINT
leddata [21] = 111111
leddata [22] = 111111
leddata [28] = 111111
leddata [29] = 111100 ' degrees c
leddata [30] = 111100
leddata [31] = 100011
leddata [32] = 111101
leddata [33] = 111101
leddata [34] = 111101
leddata [35] = 111111
LOOPing:
FOR scroll = 0 TO 35
FOR scan = 0 TO 10
PORTA=111111
PAUSE 1
PORTb = 1
FOR counter = 0 TO 7
PORTa = leddata [counter]
PAUSE 1
PORTb = PORTb * 2
NEXT
NEXT
FOR counter = 0 TO 34
leddata [counter] = leddata [counter+1]
NEXT
NEXT
GOTO START
Update : Based on the same ideea, I write the code for :
- scrolling-thermo-clock, with PIC16F877A, DS18B20, DS1307 (Thanks Mrs.Melanie for great example of using RTC - see "Calendar-clock MN1307 !) and 7x7 LED matrix (remember - DIY matrix). The time can be set, with three buttons ! ( see video how it works here http://www.youtube.com/watch?v=Zkv4EbElOCg )
; Scroll-clock-thermometer-with-16F877A
; with setting procedure
; for my DIY matrix (7x7 LED's)
; by NICULESCU DAN - october, 29, 2011
; .oooO
; ( ) Oooo.
; \_) ) /
; (_/
@ DEVICE pic16F877A, XT_OSC, WDT_ON, LVP_OFF, PWRT_ON, BOD_ON
INCLUDE "ALLDIGITAL.pbp"
OPTION_REG.7 = 0
ADCON1 = 7
PORTA = 000001
TRISA = 000001
PORTB = 000000 ' anodes of led's
TRISB = 000000
PORTC = 100000
TRISC = 100000
PORTD = 000000 ' catodes of led's
TRISD = 000000
DecButton var PORTC.6 ' Press to Decrement Button
SetButton var PORTC.7 ' Press to Set/memorise Button
IncButton var PORTC.5 ' Press to Increment Button
DQ var PortA.0 ' port for DS18B20
SDA Var PORTC.3 ' DS1307 SDA pin #5
SCL Var PORTC.2 ' DS1307 SCL pin #6
eeprom 0, [000011,110101,101101,011101,000011] '0
eeprom 5, [111111,111011,000001,111111,111111] '1
eeprom 10,[111011,111101,011101,101101,110011] '2
eeprom 15,[111101,111101,110101,101001,011101] '3
eeprom 20,[001111,010111,011011,000001,011111] '4
eeprom 25,[110001,110101,110101,110101,001101] '5
eeprom 30,[000111,101011,101101,101101,011111] '6
eeprom 35,[111001,111101,011101,101101,110001] '7
eeprom 40,[010011,101101,101101,101101,010011] '8
eeprom 45,[110011,101101,101101,101101,000011] '9
eeprom 50,[110011,101101,010011,111111,001111] 'ok
eeprom 55,[101111,101111,101111,101111,101111] 'minus
counter var byte
scan var byte
scroll var byte
leddata var byte[75] 'Column Data for display 75 columns
n var byte
TemperC Var Word
Sign Var Word
Float Var Word
Dummy Var Byte
semnul Var byte
DB Var BYTE[8] ' Data byte array
RTCSec Var DB[0] ' alias individual bytes in array
RTCDay Var DB[3]
RTCDate Var DB[4]
RTCMonth Var DB[5]
RTCYear Var DB[6]
RTCMin var byte ' Minutes
RTCHour var byte ' Hours
RTCCtrl var byte ' Control
SetSec var byte ' Seconds
SetMin var byte ' Minutes
SetDecMin Var byte
SetHour var byte ' Hours
SetDecHour var byte
TimeOut var word ' Variable for SetUp Menu Time-Out
CounterA var byte ' General purpose Variable
CounterB var byte ' General purpose Variable
CounterC var byte ' General purpose Variable
CounterD var byte ' General purpose Variable
ore var word
minute var word
oraa var byte
orab var byte
minutea var byte
minuteb var byte
okey var BYTE
ButtonRepeat con 200 ' Timeperiod in mS for Edit Buttons auto-repeat
Debounce con 250
DisplayLoop:
Clear
If SetButton=0 then
Gosub SetButtonRelease
goto Setup
' Init DS18B20 Sensor
Pause 50
Pause 50
If Temperature.15 then
Temperature= ~Temperature +1
sign="-"
sign="+"
Endif
Dummy = 625 * Temperature
TempC = DIV32 10
TemperC = (Temperature & $7FF) >> 4
Float = ((Temperature.Lowbyte & $0F ) * 25 )>>2
Temperature = TemperC*100 + Float
semnul = sign
if semnul = "+" then
For counter = 0 to 4
leddata [counter] = 111111
next
semnul = 55
READ semnul+counter,leddata [counter]
next
if tempA = 0 then
next
NEXT
NEXT
NEXT
gosub read_1307
oraa = ore dig 1
orab = ore dig 0
minutea = minute dig 1
minuteb = minute dig 0
if oraa = 0 then
leddata [counter+41] = 111111
next
READ oraa*5+counter,leddata [counter+41] 'stores tens hours digit in leddata locations
NEXT
READ orab*5+counter,leddata [counter+47] 'stores unit hours digit in leddata locations
NEXT
READ minutea*5+counter,leddata [counter+57] 'stores tens minutes digit in leddata locations
NEXT
READ minuteb*5+counter,leddata [counter+63] 'stores unit minutes digit in leddata locations
NEXT
for n=5 to 7
next n
leddata [29] = 111000 ' degrees c
leddata [30] = 111000
leddata [32] = 011101
leddata [33] = 011101
leddata [34] = 111111
leddata [36] = 111111
leddata [37] = 111111
leddata [38] = 111111
leddata [39] = 111111
leddata [40] = 111111
leddata [46] = 111111
leddata [52] = 111111
leddata [53] = 111111
leddata [54] = 010111
leddata [55] = 111111
leddata [56] = 111111
leddata [62] = 111111
leddata [68] = 111111
leddata [69] = 111111
leddata [70] = 111111
leddata [71] = 111111
leddata [72] = 111111
leddata [73] = 111111
leddata [74] = 111111
leddata [75] = 111111
' Display RTC
LOOPing:
FOR scroll = 0 TO 70
FOR scan = 0 TO 10 ' decrease for faster speed of scrolling
PORTd=111111
PAUSE 1
PORTb = 1
PORTd = leddata [counter]
PAUSE 1
PORTb = PORTb * 2
NEXT
NEXT
FOR counter = 0 TO 70
NEXT
NEXT
Pause 250 ' Repeat about 4 times/sec ; DO NOT INCREASE !!!
Goto DisplayLoop
' Clock Settings
' Initial Default Settings
SetupPreset:
RTCSec =$00 ' Seconds preset to 00
RTCMin =$00 ' Minutes preset to 15
RTCHour=$13 ' Hours preset to 13'00
RTCCtrl=$10 ' Control preset to output 1 second 'Tick' on SQWpin
' Convert the Current BCD Data to Something easier to Edit
Setup:
I2CREAD SDA,SCL,$D1,$00,[STR DB\8] ' Read 8 bytes from DS1307
ore = (db[2] & $F )+((db[2]>>4)*10) ' Hex to Dec hour
minute = (db[1] & $F )+((db[1]>>4)*10) ' Hex to Dec minutes
setdechour= ore dig 1
sethour=ore dig 0
setdecmin = minute dig 1
setmin=minute dig 0
CounterC=0 ' Set to Start of Setup (four steps from 0 to 4)
TimeOut=0 ' Zero the Time-Out counter
SetupEntryLoop:
oraa = setDechour
orab = sethour
minutea = setDecmin
minuteb = setmin
gosub staticx
' Decrement Button Pressed
If DecButton=0 then
' Decrement Tens Hours
If CounterC=0 then
If SetDecHour=0 then
SetDecHour=2
SetDecHour=SetDecHour-1
' Decrement Units Hours
If CounterC=1 then
IF setdechour=2 then
IF SetHour=0 THEN
SetHour= 3
SetHour=SetHour-1
Endif
IF sethour=0 then
SetHour=9
SetHour=SetHour-1
Endif
Endif
Endif
' Decrement Tens Minutes
If CounterC=2 then
If SetDecMin=0 then
SetDecMin=5
SetDecMin=SetDecMin-1
' Decrement Units Minutes
If CounterC=3 then
If SetMin=0 then
SetMin=9
SetMin=SetMin-1
Pause ButtonRepeat
TimeOut=0
Goto SetupEntryLoop
' Increment Button Pressed
' This is just like Decrement but opposite...
If IncButton=0 then
' Increment Tens Hours
If CounterC=0 then
If SetDecHour=2 then
SetDecHour=0
SetDecHour=SetDecHour+1
Endif
Endif
' Increment Units Hours
If CounterC=1 then
IF SetDecHour = 2 then
IF SetHour => 3 then
SetHour=0
SetHour=SetHour+1
Endif
IF SetHour=9 then
SetHour=0
SetHour=SetHour+1
Endif
Endif
Endif
' Increment Tens Minutes
If CounterC=2 then
If SetDecMin=5 then
SetDecMin=0
SetDecMin=SetDecMin+1
Endif
Endif
' Increment Units Minutes
If CounterC=3 then
If SetMin=9 then
SetMin=0
SetMin=SetMin+1
Endif
Endif
Pause ButtonRepeat
TimeOut=0
Goto SetupEntryLoop
' Set Button Pressed
If SetButton=0 then
CounterC=CounterC+1
' Increment Menu Item
TimeOut=0
If CounterC>4 then
' Save Data if all edit items exhaused
' Save Hours to BCD DS1307's Format
CounterA= (SetDecHour *10)+ SetHour
Gosub ConvertBCD
RTCHour=CounterB
' Save Minutes to BCD DS1307's Format
CounterA= (SetDecMin *10) + SetMin ; Yupppy ! I found it !
Gosub ConvertBCD
RTCMin=CounterB
' Do the Business
I2CWrite SDA,SCL,$D0,$00,[RTCSec,RTCMin,RTCHour,RTCDay,RTCMonth,RTCYear,RTCCtrl]
Pause 1000
Goto DisplayLoop
Goto SetupEntryLoop ' Loop for Next Menu Item
' Menu TimeOut Counter
Pause 1 ' Kill 1mS
TimeOut=TimeOut+1
If TimeOut>2000 then goto DisplayLoop
' User paused too long
' Return User to Time & Date Display
' This will however bounce the User to the original
' Setup Menu start point if the DS1307 has not
' been initialised
Goto SetupEntryLoop ' Loop for Button Press
read_1307: ' Read time Secs,Mins,Hours,Day,Date,Month,Year,Control
' Subroutine Converts back to BCD
' CounterA is the entry variable
' CounterB holds the converted BCD result on exit
ConvertBCD:
CounterB=CounterA DIG 1
CounterB=CounterB<<4
CounterB=CounterB+CounterA DIG 0
SetButtonRelease:
While SetButton=0:Wend
Pause 250 ' Small pause to kill any Key-Bounce
staticx: ' not perfect, but readable digits !!!
if counterc=0 then
READ oraa*5+counter,leddata [counter]
NEXT
PORTd = 255
PAUSE 1
PORTb = 1
PORTb = PORTb * 2
NEXT
if counterc=1 then
READ orab*5+counter,leddata [counter]
NEXT
PORTd = 255
PAUSE 1
PORTb = 1
PORTb = PORTb * 2
NEXT
if counterc=2 then
READ minutea*5+counter,leddata [counter]
NEXT
PORTd = 255
PAUSE 1
PORTb = 1
PORTb = PORTb * 2
NEXT
if counterc=3 then
READ minuteB*5+counter,leddata [counter]
NEXT
PORTd = 255
PAUSE 1
PORTb = 1
PORTb = PORTb * 2
NEXT
if counterc=4 then
OKEY = 50
READ OKEY+COUNTER,leddata [counter]
NEXT
PORTd = 255
PAUSE 1
PORTb = 1
PORTb = PORTb * 2
NEXT
portb=0
portd=0
pause 1
End ; of story
Original topic can be found here : http://www.picbasic.co.uk/forum/showthread.php?t=15431
Thanks to all moderators and members of PBP forum, for support and sharing knowledges ! Best regards !
Dan
LE : I dont know why some characters in code appears "strange" ... For example most of "%" are missing...So, for good codes, check the forum, to the link.
This is code partially generated by Claude. However, it gives assembly error on compilation. As I can understand, it has something to do with variables?
CuriousOne Today, 11:36ty;----[16F1937 Hardware...
