This slave relies on the work of many others, but I have added some bug fixes and extra features. For example, you can write
0xAA,0X55,0x00,**your new address here**,0x00
and you can change the address of the slave.
Like my other stuff, it ONLY works on 18F chips. It should be "plug and play" in virtually any 18F chip.
ifndef __18F2321
error "18F2321 not selected"
movlw 0x62 ; %0110 0010 = 4 Mhz, internal osc block
movwf OSCCON
movlw 0x80 ; %1000 0000 = PLL disabled
movwf OSCTUNE
DATA @0,$38 ; Default I2C address if not determined in HW
Define USE_LFSR 1
;---------------- Alias the bits ------------------------------------
SSPIF VAR PIR1.3 ' SSP (I2C) interrupt flag
SSPIE VAR PIE1.3 ' Int Enable
SSPUA VAR SSPSTAT.1
SSPS VAR SSPSTAT.3
SSPP VAR SSPSTAT.4
SSPSMP VAR SSPSTAT.7
BF VAR SSPSTAT.0 ' SSP (I2C) Buffer Full
R_W VAR SSPSTAT.2 ' SSP (I2C) Read/Write
D_A VAR SSPSTAT.5 ' SSP (I2C) Data/Address
CKP VAR SSPCON1.4 ' SSP (I2C) SCK Release Control
SSPEN VAR SSPCON1.5 ' SSP (I2C) Enable
SSPOV VAR SSPCON1.6 ' SSP (I2C) Receive Overflow Indicator
WCOL VAR SSPCON1.7 ' SSP (I2C) Write Collision Detect
MasterClock VAR WORD BANKA SYSTEM
'------------------- Buffer defintion --------------------
RxBufferLEN con 10
RxBuffer var BYTE[Rxbufferlen + 1]
TxBufferLEN CON 10
TXBuffer VAR BYTE[TxBufferLEN + 1]
GeneralCall VAR BIT
RXBufferOverFlow VAR BIT
TxBufferUnderFlow VAR BIT
HWAddress VAR BIT
RXBufferPointer VAR Byte
TXBufferPointer VAR Byte
address VAR BYTE
x VAR BYTE
dummy var byte
I2CAddress VAR BYTE
WCOLCounter VAR BYTE
I2CDeviceAddress VAR BYTE
Holdoff VAR WORD ; retry timer
HWAddress = 0 ; Get address from EEPROM, not pins
TestArray VAR BYTE [200]
IF !HWAddress THEN
;----------- Get our Address from EEPROM --------------
READ 0,I2CAddress
;----------------OR Get our address from PORT B0..2-----------
I2CDeviceAddress = PORTB & %00000111
I2CMajorAddress CON $3 ; upper 4 bits
I2CAddress = (I2CMajorAddress <<4) | I2CDeviceAddress <<1 ; bit 0 is R/W
Endif
SSPADD = I2Caddress ' Move our address into the proper reg
SSPCON2.0 = 1 ; Allow clock stretching
SSPCON2.1 = 0 ; Set to 1 to enable masking of address 1 ; 0 is R/W bit
SSPCON2.2 = 0 ; Set to 1 to enable masking of address bit 2
SSPCON2.3 = 0 ; Set to 1 to enable masking of address bit 3
SSPCON2.4 = 0 ; Set to 1 to enable masking of address bit 4
SSPCON2.5 = 0 ; Set to 1 to enable masking of address bit 5
SSPCON2.6 = 0 ; Not used in slave
SSPCON2.7 = 1 ; General Call enabled
SSPSTAT = 0
SSPEN = 1
SSPIE = 1
SSPIF = 0
SSPCON1 = $36 ' Set to I2C slave with 7-bit address
TRISA = %11111111
TRISB = %11111111
TRISC = %11111111
' -------------- Turn on Ints ------------------------
INTCON.7 = 1 ; global ints
INTCON.6 = 1 ; peripheral ints
IPR1.3 = 1 ; high priority
;------------------ Clear parameters --------------
RXBufferPointer = 0
TxBufferPointer = 0
GeneralCall = 0
RxBufferOverFlow = 0
TXBufferUnderFlow = 0
WCOLCounter = 0
;----------------Timer Setup-----------------------------------
T0CON = %10000011 ; /16 prescaler
WDTCON = 1 ; Turn on the WDT
INCLUDE "DT_INTS-18.bas" ' Thanks Darrel!
INCLUDE "ReEnterPBP-18.bas" '
INT_Handler SSP_INT, _I2C_Int, PBP, yes
INT_Handler TMR0_INT, MainTimer, ASM, yes
endasm
''----------------- Initialization Done! -----------------------------
Goto OverInt ; jump over ISR, don't execute it.
;----------------------- Timer INt ------------------------------------
MainTimer
movlw 0x00 ; 10 mSec
movwf TMR0H
movlw 0x63
movwf TMR0L
infsnz MasterClock
incf MasterClock + 1
; This is a good place to pick up pin changes
INT_ENABLE TMR0_INT
INT_RETURN
'------------------------- I2C subroutine --------------------------------
I2C_Int:
; We don't get here uless someone has matched our address register.
If R_W = 0 then 'This is a WRITE by the master to us
IF BF = 0 Then goto i2CEXIT ; Nothing for us!
if D_A = 0 then 'We have an address
address = SSPBUF 'Need to READ Address from buffer to clear it.
IF Address = 0 THEN
GeneralCall = 1 ; Set flag if we got a general call address
GeneralCall = 0
IF WCOL OR SSPOV THEN I2CExit
IF RXBufferPointer < RxBufferLen - 1 THEN
RXBuffer [RxBufferPointer] = SSPBuf ;
RxBufferPointer = RXBufferPointer + 1
Dummy = SSPBuf ; Grab the data but don't overwrite old
RXBufferOverFlow = 1
else ' R_W = 1 Master wants to read FROM us
IF !D_A Then
TxBufferPointer = 0 ' Mark as first read
RXBufferPointer = 0
EndIF
IF CKP THEN I2CExit
dummy = SSPBUF ;NECESSARY!
SENDI2C:
WCOL = 0
SSPBUF = TXBuffer[TXBufferPointer] ' Get data from array
IF WCOL THEN
WCOLCounter = WCOLCounter + 1 ; Don't hang the bus with infinite WRITES!
IF WColCounter >= 7 Then goto I2CExit ; 7
RANDOM Holdoff
Pauseus Holdoff >> 3 ; wait 0-8 msec
Goto SendI2C ; Retry
WColCounter = 0
TXBufferPointer = TXBufferPointer + 1
If TXBufferPointer = TXBufferLen THEN
TXBufferUnderflow = 1
TXBufferPointer = TXBufferLen - 1 ; Repeat last if req made again, but set flag now
I2CEXIT:
SSPOV = 0
BF = 0
sspif = 0
CKP = 1
@ INT_ENABLE SSP_INT ; probably don't need this, but I like to be certain it gets restarted
' -------------------------end I2C subroutine --------------------------------
'--------------------[End ISRs]---------------------------------------
OverInt:
@ INT_ENABLE TMR0_INT
'--------------------[ main program loop]---------------------------------------
IF RXBuffer[0] = $AA THEN
IF RXBuffer[1] = $55 and RXBuffer[2] = 0 And RxBuffer[4] = 0 THEN
Dummy = RXBuffer[3]
WRITE 0,Dummy ; Write a new address
Pause 10
@ RESET ; and pick up the new address
;------------------- Load the input buffer to the output buffer for test -----------
For X = 0 to TXBufferLen - 1
TxBuffer[X] = RXBuffer[X]
next x
ORG 0x0FF0 ; Keep track of pgm size in case we want to use it on a smaller chip
NOP
