<<< DOWNLOAD THE FILE HERE: NineServo.pbp >>>
SOURCE CODE:
'*************************************************************************** '* Name : NINESERVO.pbp * '* Author : Antoine Bercovici * '* Date : 12/23/2010 ,;22ZB088ZZSS, * '* Version : 1.0 7WMM@MB00ZZ0BW0@B@MMW2 * '* iM@0Z28ZXZ877Sa0W8XZWB@MM. * '* M0SSXa0Z20;. ;Wa2aa2SZaZ * '* 80Wa2Z27X28r.;X777S2a8a;SS XX * '* M2a80S0BZZ0BW88a002rriSW@W00MMi * '* X0MMBaZaZZaSZZ8Za22XXS0MMMMMMWM iMM * '* ;XXa0Z@MMMM@WBB@BB08a2ZBMMBr 7@M@88MM8; * '* ,Z@ZZ77X;:i;aWMM@MMMMMM@@MMM, MM0i * '* @MBaXa22S7iri;:.222aXrir20@Mi r@MMMi SM * '* i0M@@0ZSXX2aaX7Sr,..,:r72Z00M MMWB@M; iM ;a8S * '* BMX:;S0W@0822aZaS7X7aZ0BWBW0M MMWWMMS ;MX2Ba; * '* ZMMM2;,;SBW@BZXr:iXBB08BM@X8@ MMMMS r a@Ma * '* [email protected],:;ZBB088W@ WM M; MM * '* MMM. ,Zi:iX8MM@Si:S0MMMMB0@M @008 7WM8 0WM * '* .@27;X2222XS0MB800r rMMM ,@8ZZWMMMMMMMr BMMW * '* ,8WZW@W@BX,i72Z0Z ; XM0ZZ8S rBS. XMMa * '* @M2i:rS8B@WZZ0WBi aM@0Z0; S0S * '* 8M@B0BWB@WWS22Z0M0 ,288MM@0ZX, * '* SMMM@@BBBW022ZZ@S Z@i BM8X. * '* .0MMM@BWBB22aW7 ZWWMM882. * '* :WMMM@BZ2W: @MMW2, * '* i@MMBW7 ;MBi * '* .Xi.: * '* * '* USAGE 1. This interrupt update the position of nine servos using * '* only two I/O lines and an external CD4017. Resolution for * '* each servo channel is 11bit (0 to 2047) and signal period is * '* 22ms (about 45Hz). * '* 2. The interrupt is triggered by a 16bit timer (Timer1) using * '* Darrel Taylor's Instant interrupt routines. Don't forget to * '* include these two files in your project folder * '*************************************************************************** ASM __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _BOREN_OFF & _LVP_OFF & _CP_OFF ENDASM DEFINE OSC 4 DEFINE LOADER_USED 1 clear '******************************************************* 'I/O port declaration '******************************************************* ServoClock VAR PORTB.0 ServoReset VAR PortB.1 '******************************************************* 'Variable declaration '******************************************************* ServoValue VAR WORD[9] 'Resolution of each channel is 11bit (0 to 2047) ServoTemp VAR WORD InvertedValue VAR WORD ServoID VAR BYTE i VAR WORD '******************************************************* 'Init for PIC16F628A '******************************************************* CMCON = %00000111 'Disable comparator module TRISA = %00000000 'All PortA is output TRISB = %00000000 'All PortB is output T1CON = %00000001 'Set Timer1 ON at 1Mhz running from internal oscillator with /1 prescaler '******************************************************* 'Init the interrupt handling system '******************************************************* INCLUDE "DT_INTS-14.bas" 'Base Interrupt System INCLUDE "ReEnterPBP.bas" 'Include if using PBP interrupts ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler TMR1_INT, _ServoUpdate, PBP, Yes endm INT_CREATE ; Creates the interrupt processor ENDASM '******************************************************* 'Main Program '******************************************************* wsave VAR BYTE $70 SYSTEM 'alternate save location for W, for DT_INTS use ServoID = 9 InvertedValue = 0 @ INT_ENABLE TMR1_INT ; enable Timer 1 interrupts MainLoop: 'Example routine that rotates all servo position counterclockwise FOR i = 0 TO 2047 ServoValue[0] = i ServoValue[1] = i ServoValue[2] = i ServoValue[3] = i ServoValue[4] = i ServoValue[5] = i ServoValue[6] = i ServoValue[7] = i ServoValue[8] = i PAUSE 10 NEXT i GOTO MainLoop '******************************************************* 'Timer1 Interrupt Handler '******************************************************* ServoUpdate: IF ServoID >= 9 THEN HIGH ServoReset ServoTemp = 65535 - InvertedValue InvertedValue = 18423 'Initialize the remaining time to its maximum value, 9*2047 ServoID = 0 LOW ServoReset ELSE HIGH ServoClock ServoTemp = 65270 - ServoValue[ServoID] 'Offset value for servo centerpoint (1.5ms) InvertedValue = InvertedValue - ServoValue[ServoID] 'Compute the remaining time to be added at the end ServoID = ServoID + 1 LOW ServoClock ENDIF TMR1H = ServoTemp.BYTE1 'Update the timer value for next interrupt when overflow TMR1L = ServoTemp.BYTE0 @ INT_RETURN END
In fact, it is similar to the decoding stage found in many PPM radio receiver, where the servo position is encoded as a pulse train with variable durations. The signal is reconstructed by clocking the 4017 using this signal, and the active output advances to the next pin with the predefined delay each time the counter is clocked.
Signal generated.
All current radios assume that a high level of 1.5 ms is control centered. The range of variation for servo position (-90° to +90°) is 1.0 to 2.0 ms. However variations does exists and it is preferable to go beyond these limits to get the full range of movement. The program given herein provides for a pulse period of 22ms (about 45Hz), with a PWM resolution of 11bit per channel (values from 0 to 2047). 1023 correspond to the center value, and the two extreme goes slightly beyond the capability of the servos (about -92° to +92°).
Each servo position are then updated one after another, instead of all at the same time. The output Q0 is not available for use as it is used to reconstruct the final timing necessary to get the 22ms signal period. At this rate, the interruption routine is called about 450 times per seconds.
Variations can easily be made using shift registers instead of decade counters with minor changes to the code.
lester Today, 06:43
