With an 18F.
Servo outputs are the CCP? pins.
Pulses will be continuous at ~40hz, regardless of MainLoop activity.
Cheers ...
'* Name : 2CH_Servo.pbp
'* Author : Darrel Taylor
'* Date : 12/13/2009
'* Notes : 18F's only
@ __CONFIG _CONFIG1H, _OSC_HSPLL_1H
@ __CONFIG _CONFIG2L, _BOREN_OFF_2L
@ __CONFIG _CONFIG2H, _WDT_OFF_2H
@ __CONFIG _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
CLEAR
DEFINE OSC 40
DEFINE INTHAND myint
;----[User Selections]------------------------------------------------------
MoveSpeed CON 3 ' movement speed smaller = faster
PosRange CON 900 ' position is 0-900, 0.0-90.0 degrees
' 450 is Center
CCP1pin VAR PORTC.2 ' Specify the pin that CCP1 uses
CCP2pin VAR PORTC.1 ' Specify the pin that CCP2 uses
;----[Variables and Aliases]------------------------------------------------
Servo1 VAR WORD ' Position for Servo1
Servo2 VAR WORD ' Position for Servo2
DutyHold1 VAR WORD BANK0 SYSTEM ' holds next dutycycle, synch with PWM
DutyHold2 VAR WORD BANK0 SYSTEM '
TempW VAR WORD ' temporary variable
POS VAR WORD ' loop counter variable
TMR1IE VAR PIE1.0 ' Timer1 Interrupt Enable
TMR1IF VAR PIR1.0 ' Timer1 Interrupt Flag
TMR1ON VAR T1CON.0 ' Timer1 ON bit
GIE VAR INTCON.7 ' Global Interrupt Enable
PEIE VAR INTCON.6 ' Peripheral Interrupt Enable
;----[Initialization]-------------------------------------------------------
Init:
T1CON = %00100000 ' Timer1 off, Prescaler 1:4 (40mhz)
' 1:2 (20mhz), 1:1 (10mhz)
TMR1IE = 1 ' Enable TMR1 overflow interrupt
TMR1IF = 0 ' Clear TMR1 interrupt flag
PEIE = 1 ' Enable peripheral interrupts
GIE = 1 ' Enable global interrupts
CCP1CON = 9 ' Low on match TMR1 with DUTY1
CCP2CON = 9 ' Low on match TMR1 with DUTY2
OUTPUT CCP1pin ' Set CCP1 pin to output, starts High
OUTPUT CCP2pin ' Set CCP1 pin to output, starts High
Servo1 = PosRange/2 ' Start at Center Position
Servo2 = PosRange/2
GOSUB SetServos
TMR1ON = 1 ' turn ON TMR1
PAUSE 2000 ' allow time for servo to Home
;----[Main Program Loop]----------------------------------------------------
FOR POS = 0 TO PosRange ' move both from one end to the other
Servo1 = POS
GOSUB SetServo1 ' Set servo1's position
Servo2 = POS
GOSUB SetServo2 ' Set servo2's position
PAUSE MoveSpeed ' movement speed
NEXT POS
FOR POS = PosRange TO 0 STEP -1 ' move servo1 back to home
Servo1 = POS
GOSUB SetServo1
PAUSE MoveSpeed
NEXT POS
FOR POS = PosRange TO 0 STEP -1 ' move servo2 back to home
Servo2 = POS
GOSUB SetServo2
PAUSE MoveSpeed
NEXT POS
PAUSE 1000
Goto Main ' rinse and repeat
;----[Convert Position in degrees to dutycycle]-----------------------------
SetServos: ' Set both Servo's dutycycles
GOSUB SetServo1
SetServo2: ' scale Posistion to 2500 Dutycycle
TempW = Servo2 * 2500
TempW = DIV32 PosRange + 2500
GIE = 0 ' no ints during variable update
DutyHold2 = TempW
GIE = 1
SetServo1:
TempW = Servo1 * 2500
GIE = 0
DutyHold1 = TempW
GIE = 1
;----[Dual Servo Driver - Interrupt Service]--------------------------------
Asm
myint
movlw 9 ; %00001001 compare mode, low on match
clrf CCP1CON ; clrf added per Bruce's suggestion
movwf CCP1CON ; Set Pins to default state (High)
clrf CCP2CON ; clrf added per Bruce's suggestion
movwf CCP2CON
movf DutyHold1+1,W ; update current position's dutycycle
movwf CCPR1H ; for both servos
movf DutyHold1,W
movwf CCPR1L
movf DutyHold2+1,W
movwf CCPR2H
movf DutyHold2,W
movwf CCPR2L
bcf PIR1,0 ; Clear Timer Int Flag
retfie FAST ; Return from interrupt with shadow regs
EndAsm
