Click image for larger version.
;----[USART Settings]-------------------------------------------------------
DEFINE HSER_TXSTA 24h ' Enable transmit, BRGH=1
DEFINE HSER_SPBRG 25 ' 9600 Baud @ 4MHz, 0.16%
;----[LCD Settings]---------------------------------------------------------
DEFINE LCD_DREG PORTA ' LCD data port
DEFINE LCD_DBIT 4 ' LCD data starting bit 0 or 4
DEFINE LCD_RSREG PORTA ' LCD register select port
DEFINE LCD_RSBIT 2 ' LCD register select bit
DEFINE LCD_EREG PORTA ' LCD enable port
DEFINE LCD_EBIT 3 ' LCD enable bit
DEFINE LCD_BITS 4 ' LCD bus size 4 or 8
DEFINE LCD_LINES 2 ' Number lines on LCD
DEFINE LCD_COMMANDUS 2000 ' Command delay time in us
DEFINE LCD_DATAUS 50 ' Data delay time in us
;----[A/D Settings]---------------------------------------------------------
DEFINE ADC_BITS 10 ' ADCIN resolution (Bits)
DEFINE ADC_CLOCK 1 ' ADC clock source (Fosc/8)
DEFINE ADC_SAMPLEUS 11 ' ADC sampling time (uSec)
;----[Variables]------------------------------------------------------------
GraphMAX VAR WORD
GraphMIN VAR WORD
GraphVal VAR WORD
X VAR WORD
ADval VAR WORD
Xmax VAR WORD
Xmin VAR WORD
char VAR BYTE
OverRange VAR BIT
UnderRange VAR BIT
;----[Aliases]--------------------------------------------------------------
RCIF VAR PIR1.5
OverPin VAR PORTC.5
UnderPin VAR PORTC.4
;----[Default Values]-------------------------------------------------------
GraphMAX = 100
GraphMIN = 0
Xmax = 100
Xmin = 0
;----[Initialize]-----------------------------------------------------------
PORTB = 0
TRISB = 0
PORTD = 0
TRISD = 0
ANSEL = %00000001
ANSELH = 0
ADCON1.7 = 1
PAUSE 250 : LCDOUT $FE,1 : PAUSE 250 : LCDOUT $FE,1
GOSUB ShowMenu
GOSUB ShowLimits
OverRange = 0
UnderRange = 0
;----[Main Program Loop]----------------------------------------------------
IF RCIF THEN GOSUB Terminal
GOSUB GetAD
GOSUB ShowGraph
GOSUB CheckOverUnder
;----[Get and Scale Analog Reading]-----------------------------------------
GetAD:
ADCIN 0, ADval
X = ADval * (Xmax - Xmin)
X = DIV32 1023 + Xmin
LCDOUT $FE,$80, "AD=",DEC ADval, " "
LCDOUT $FE,$8B, "X=",DEC X, " "
;----[Show the BarGraph]----------------------------------------------------
ShowGraph:
IF X > GraphMAX THEN
OverRange = 1
OverRange = 0
IF X < GraphMIN THEN
UnderRange = 1
UnderRange = 0
X = (X MIN GraphMAX) MAX GraphMIN
;-- This is the formula being tested ---------------------
GraphVal = $FFFF >> (16-(((X - GraphMIN) * 16) / (GraphMAX - GraphMIN)))
PORTD = GraphVal & $FF
PORTB = GraphVal >> 8
;----[Show Menu for Terminal]-----------------------------------------------
ShowMenu:
HSEROUT ["MENU: 1=GraphMAX, 2=GraphMIN, 3=Xmax, 4=Xmin :"]
;----[Handle the RS232 Terminal]--------------------------------------------
Terminal:
HSERIN [char]
SELECT CASE char
CASE "1" : HSEROUT [13,10,"Enter the GraphMAX: "]
HSERIN [DEC GraphMAX]
CASE "2" : HSEROUT [13,10,"Enter the GraphMIN: "]
HSERIN [DEC GraphMIN]
CASE "3" : HSEROUT [13,10,"Enter the Xmax: "]
HSERIN [DEC Xmax]
CASE "4" : HSEROUT [13,10,"Enter the Xmin: "]
HSERIN [DEC Xmin]
CASE ELSE : HSEROUT [7]
END SELECT
;----[Show Limits]----------------------------------------------------------
ShowLimits:
LCDOUT $FE,$C0," GRAPH X "
LCDOUT $FE,$94,"MAX: "
LCDOUT $FE,$D4,"MIN: "
LCDOUT $FE,$99,DEC GraphMAX
LCDOUT $FE,$D9,DEC GraphMIN
LCDOUT $FE,$A1,DEC Xmax
LCDOUT $FE,$E1,DEC Xmin
;----[Look for Over and Under Range]----------------------------------------
BlinkSpeed CON 50
BlinkCount VAR WORD
CheckOverUnder:
BlinkCount = BlinkCount + 1
IF BlinkCount = BlinkSpeed THEN
BlinkCount = 0
IF OverRange THEN
TOGGLE OverPin
LOW OverPin
IF UnderRange THEN
TOGGLE UnderPin
LOW UnderPin
Yes sure.
