For a little more info on the original average routine, and some more explanations, see http://www.pbpgroup.com/modules/wfse...hp?articleid=7
'* Name : Average_Hyst.pbp *
'* Author : Darrel Taylor *
'* Date : 7/19/2005 *
'* Version : 3.0 *
'* Notes : Modified to use Hysteresis *
'* : Use as an INCLUDE file *
' This routine will keep a "Running Average" of 10-bit Analog Values
' Instead of adding a bunch of values together and then dividing by the number
' of samples, it averages each sample into the final result immediately.
' This eliminates the need for 32 bit math.
' To allow it to "Catch up" to large changes, set the FAspread to an
' acceptable range.
' Simply place the new number in VALUE and GoSub Average
' The Average (with Hysterisis) will be returned into the same variable VALUE
'---- [ User Options ] ---------------------------------------------------------
HystLevel CON 7 ' 7 = .7 of the Least Significant Digit
' Valid HystLevel is from 6 to 13
AvgCount CON 16 ' = Number of samples to average. For best response
' times, keep AvgCount as small as you can
FAspread CON 50 ' = Fast Average threshold +/-
' FAspread should be larger than the worst possible
' noise in the A/D conversion.
AVGchanged VAR BIT ' 1 indicates that the Average Value has changed
' you have to clear this bit after using it
ADavg VAR WORD ' Stores the current Average
ADhyst VAR WORD ' Stores the current Value for Hysterisis
Value VAR WORD ' Input / Output variable to be averaged
spread CON FAspread * 10 ' adjust spread *10 for Hyst.
GOTO OverAverage
' -=-=-=-=-=-= Average Analog values -=-=-=-=-=-=-=-=-=-=
Average:
Value = Value * 10 ' Scale value up for hysterisis
IF Value = ADavg Then NoChange ' if they're the same, nothing to do
IF ABS (Value - ADavg) > spread OR Value < AvgCount Then FastAvg
IF ABS (Value - ADavg) < AvgCount Then RealClose
ADavg = ADavg - (ADavg/AvgCount) ' Subtract 1 samples worth
ADavg = ADavg + (Value/AvgCount) ' Add in the new sample portion
GoTo AVGok
FastAvg: ' Catch up to the changing value
ADavg = Value ' Set Average to the current value
GoTo AVGok
RealClose: ' Reduce the sample size when
ADavg = ADavg - (ADavg/(AvgCount/4)) ' the average and the sample are
ADavg = ADavg + (Value/(AvgCount/4)) ' "Real Close"
AVGok:
IF ABS (ADavg - ADhyst) > HystLevel then ' If it changed > HystLevel +/-
ADhyst = ((ADavg + 5) / 10) * 10 ' Round ADavg to get new Value
AVGchanged = 1 ' Indicate that Average changed
NoChange:
Value = ADhyst / 10 ' Scale the result down
OverAverage:
