with better resolution than PULSIN?
Here's how .. with an example from the Microchip CCP & ECCP Tips & Tricks modified to
work with PBP.
' Measuring signal pulse widths with capture module
' Procedure for high-going pulse:
' 1. Configure CCP to capture on rising edge
' 2. Setup Timer1 so it will not overflow during max pulse width time
' 3. Enable ccp capture
' 4. Once capture flag bit is set, save captured value as T1
' 5. Reconfigure CCP to capture on falling edge
' 6. On 2nd capture, save 2nd value as PW
' 7. Subtract T1 from PW for the pulse width value
Symbol Capture = PIR1.2 ' CCP1 capture flag
T1 VAR WORD ' 1st capture value
PW VAR WORD ' 2nd capture value & ultimately final pulse width
TRISC.2 = 1 ' CCP1 input pin (Capture input on 18F242)
INTCON = 0 ' Interrupts off
ReLoad:
CCP1CON = %00000101 ' Capture mode, capture on rising edge
T1CON = 0 ' TMR1 prescale=1, clock=Fosc/4, TMR1=off
TMR1H = 0 ' Clear high byte of TMR1 counter
TMR1L = 0 ' Clear low byte
T1CON.0 = 1 ' Turn TMR1 on here
Capture = 0 ' Clear capture int flag bit
While !Capture ' Wait here until capture on rising edge
Wend
' Rising edge detected / stuff 'captured' Timer1 value in T1
T1.HighByte = CCPR1H
T1.LowByte = CCPR1L
CCP1CON.0 = 0 ' Configure capture for falling edge now
Capture = 0 ' Clear capture interrupt flag bit
While !Capture ' Wait here until capture on falling edge
Wend
' Falling edge detected / stuff 'captured' Timer1 value in PW
PW.HighByte = CCPR1H
PW.LowByte = CCPR1L
PW = PW-T1 ' High pulse width = PW-T1
HSEROUT [DEC PW,"uS High",13,10] ' Output to RS232 display
GOTO ReLoad
the falling edge first with CCP1CON = %00000100, and rising edge next with
CCP1CON.0 = 1.
Real simple ... real effective ... and spot-on timing. Even works on tiny little PICs
like the 12F683 12F615, etc...;o)
Thank you Lester for the details and your efforts to explain.
Ioannis Yesterday, 12:39Makes sense why to use many models.
Great tools we have now. Have to make clever use of them as you showed with detailed examples....
