From £49.95 |
Buy it Now LAB-X1 Bare PCB only* (With surface-mount oscillator multiplier attached, diskette and schematic.) |
MenuBeep and just notes is easy and very different than music playing. Not compatible between them.
But both are supported by the PBP.
All I need is loud beeper sounds, just with ability to have exact note frequencies.
Ioannis - 14th May 2026, 12:51
lester - 13th May 2026, 06:43
ty;----[16F1937 Hardware...
I even tried to connect external amplifier.
Freqout has way too many harmonics, at frequencies close to the original sound, so unfortunately, not usable.
Thank you Richard for pointing me to the right direction.
Everything is working now :)
Cheers
The FREQOUT is the way to go.
You did not post the circuit of transistor amplifier. I suppose you did add a good bias to the transistor, right?
Its all been done before. See original post#12 where process is elaborated from that post
richard - 11th May 2026, 08:55
From £49.95 |
CuriousOne Yesterday, 15:088 note polyphony with multiple sinewave per single note.
