From £4.50 |
Buy it Now For the 14-pin PIC® 16C505, 16F630, 16F676 and the 8-pin PIC® 12C508(A), 12C509(A), 12C671, 12C672, PIC® 12CE518, 12CE519, 12CE673, 12CE674, 12F629, 12F675 microcontrollers. |
Menuthe output is intended to be plotted in the freely available easy to use arduino plotter, the average human will have nil chance of interpreting the data with such a small number of samples. if your...
richard Today, 00:55
you cannot use a current transformer that way without a burden resistor.
by voltage sensor do you mean ACS712 or similar ?
if so that circuit is incorrect, typical use
10022
Sorry guys for not reponding earlier - I'm still waiting for 20A:50mA current sensor to arrive; my 100A:50mA are far too low and "out of range" for what I intend to measure.
BUT I could grab a...
adjust resister to for the mid current used incase of some nonlinearity... shotkey diode has .3 volt drop
10016
You might want to specify the model number of the sensor since there are a number of different types, and the circuit shown may not even apply
tumbleweed - 2nd December 2025, 00:26
Have you connected your CT as shown in your first post? That is, the bottom to 2.5V (or VRef/2) and the top to input pin AND - VERY IMPORTANT - a load resistor shown as 33ohms in diagram? You must...
HenrikOlsson - 1st December 2025, 22:20
It can't work wired the way you described. The ac signal must be biased by vcc/2 and be less than vcc peak to peak.
If the serial baud rate is too low it will ruin the sample rate.
If the burden...
Richard,
I've connected my YHDC sensor one pin to ground and the other to RA5. Got readings (see hereunder).
Because I'm not sure what I'm doing right now with the current sensor, I tried to...
...sorry Richard, didn't try your code by now - still in office.... 😬
flotulopex - 1st December 2025, 14:25
From £4.50 |
Re: YHDC current sensor - the theory please
sample data
richard Today, 01:34ADC:1632,peak:608ADC:2447,peak:608
ADC:3224,peak:608
ADC:3704,peak:608
ADC:3722,peak:608
ADC:3312,peak:3722
ADC:2528,peak:3722
