From £34.95 |
Buy it Now Specifically for the 28-pin PIC® 14C000. |
MenuLester, what you posted is a masterpiece of AI User Manual! Thank you very much for the effort to explain in such detail how to best use the AI tools, like Claude.
CuriousOne: I am pretty sure...
CuriousOne - 24th May 2026, 19:32
Feeding Complex Documents to Claude — How AI Reads a Datasheet and Why It Matters
The Problem With Giving Claude a 472-Page Datasheet
The PIC16F1936 datasheet is 472 pages. It covers...
Taking Control of Claude — Setting Up a Basic User Profile Prompt for PBP3 Development
What is a System Prompt and Why Should You Care?
When you open a conversation with Claude and...
Getting Better Results from AI When Debugging PicBasic Pro 3 Code
A Complete Guide to Using Claude Projects for PBP3 Development
Why Most AI-Assisted PBP3 Debugging Falls Short
looks like not much has changed, evidently your AI does not understand PIC hardware instruction sets.
i still maintain that if you don't know how the hardware works you cannot tell when the AI...
This is code partially generated by Claude. However, it gives assembly error on compilation. As I can understand, it has something to do with variables?
ty;----[16F1937 Hardware...
Dealing with Hallucinated Code: A Working Engineer's Guide to AI and PIC BASIC Pro
lester Today, 06:32Most experienced embedded engineers treat AI-generated code with suspicion. That's the right instinct. When...
