Color sensor distance problem
Results 1 to 9 of 9
    Sep 2008
    Default Color sensor distance problem
    I want to detect three colors(RGB) by using a circuit.I tried LDR and three leds(red,green,blue) but they are not sensitive.For example I can not detect colors more than 5 cm away.It should detect at least 10 cm away from LDR.
    What do you suggest?Should I use other thing?
    sinoteq's Avatar
    sinoteq Guest
    Default Why not?
    Test one of these, not that bad price and is made for detecting colour.
    TCS230 from TAOS.
    Sep 2008
    this is my circuit.I used two blue leds one for red one for green.Black thing in the middle is LDR.How can I increase the sensibility(range of measurement)????
    Quote Originally Posted by burak450 View Post
    Lenses? Collimator?
    Jan 2006
    Istanbul
    Ambient light sensitive photo diode is the way to go.
    Many different versions available in the market, arkadaşım.
    Hi burak450,
    I scrapped out a video camcorder once, it had a unit composed of 3 chambers, 3 colored filters and 3 light sensors, presumably used for color correction, the filters were as you might have guessed red blue green. This unit was mounted on the front top of the camera above the lens.
    Sep 2008
    I am sorry, but I dont get most of answers.HOw can I use lenses in this project?Is there any example?
    I tried photodiode earlier.I didnt have right results.What kind of photodiode should I use? For example???
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 19:52
  2. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  3. Microcode Studio 18f2455 problem?????
    By volkan in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 21:04
  4. Hardware problem or what ?
    By Steve S. in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 21:39
  5. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 22:59
