Writing & Reading to iButton EEPROM
Results 1 to 3 of 3
    Apr 2007
    Santiago, Chile
    Default Writing & Reading to iButton EEPROM
    '* How to write and then read back from an iButton EEPROM *
    '* DS1973 or the equivalent 1-wire device, the DS2433 EEPROM. *
    '* : All Rights Reserved *
    @ device hs_OSC, wdt_on, pwrt_on, protect_off
    DEFINE OSC 20
    iButton var PortD.2 'Connected iButton on 16F877 at this port.
    RESULT VAR BYTE[19] 'Byte array to put string of characters into.
    IN VAR BYTE 'Byte to collect the 1 byte you want to read.
    Taddr var byte[2] 'Target address 2 bytes (TA1 & TA2)
    ES var byte 'Ending offset data status (E/S)
    IN=0
    RESULT=0
    '(Just connect your serout to to the serial communicator @ 19200)
    START:
    'WRITE TO EEPROM
    OWOUT ibutton,1,[$CC,$0F,$00,$00] 'Write to scratchpad
    OWOUT IBUTTON,0,["Testing this EEPROM",10,13] 'Write a few characters or values into EEPROM
    OWout IBUTTON,1,[$CC,$AA] 'get ready to read scratchpad
    owin ibutton,0,[Taddr[0],Taddr[1],ES] 'read back the scratchpad to get the Authorisation code
    owout ibutton,1,[$CC,$55] 'Write back the contents of the target address & E/S register
    'to allow copy scratchpad to take place.
    owout ibutton,0,[Taddr[0],Taddr[1],ES] 'Enter Authorisation code as TA1,TA2,E/S
    PAUSE 25 'Give EEPROM time to write
    'READ STRING OF BYTES FROM EEPROM
    OWOUT ibutton,1,[$CC,$F0,$00,$00] 'Read scratchpad
    OWIN IBUTTON,0,[STR RESULT\7] '
    PAUSE 1 'Not really nessesary
    SEROUT2 PORTD.7,16416,[RESULT],10,13] 'You should get the full string you put in.
    'READ 1 BYTE FROM SPECIFIC ADDRESS
    OWOUT ibutton,1,[$CC,$F0,$010,$00] 'Read from address $10, first byte of
    'target address is the Least Significant.
    OWIN IBUTTON,0,[IN]
    SEROUT2 PORTD.7,16416,[IN] 'You should get the letter "T"
    Thanks Chris !
    Nice job! Will be useful.
    Last Post: - 18th February 2010, 14:46
  2. Writing, Reading from Internal PIC EEPROM
    By NO2K in forum mel PIC BASIC Pro
    Last Post: - 4th October 2007, 00:35
  3. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 06:26
  4. reading, writing, and displaying from eeprom
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 12th January 2006, 22:05
  5. Writing / Reading EEPROM 24LC256 Problem
    By schmoddel in forum mel PIC BASIC Pro
    Last Post: - 27th February 2004, 18:55
