Efficient comparison on data (iButton)
+ Reply to Thread
Results 1 to 8 of 8
    Lancashire
    Default Efficient comparison on data (iButton)
    Hi All
    Having completed the code for DS1990A reading (thanks Darrel) I have a working code section but I`m looking for a much more efficient way to compare the results. Code section included below for reference. The individual iButtons are used to identify room access by person.
    The iButton id number is contained in these variables, 6 hex bytes:
    id[0],id[1],id[2],id[3],id[4],id[5]
    Assuming there is a button in the socket, whats the best way to do a compare to see if its the same button or a different one, without strings of comparsons against the last valid number?
    Cheers Pete
    Fam var byte
    id var byte[6]
    crc var byte
    OWOUT portb.0,1,[$33], NotThere ' Issue Read ROM, jump to NotThere if no button
    OWIN PORTA.1,0,[Fam,id[0],id[1],id[2],id[3],id[4],id[5],crc] 'Read the button
    (code required)
    NotThere:
    id[0]=0:id[1]=0:id[2]=0:id[3]=0.id[4]=0:id[5]=0 'set all to zero if no iButton inserted
    skimask's Avatar
    skimask Guest
    Quick and dirty, add all 6 bytes together into a word and compare that number to the 'new' number. If they're not equal, you know you've got a different button. If they're the same, you MIGHT NOT have the same button and have to do further comparisons.
    Any way you go, you're going to have to do some comparisons somewhere...
    A bit less quick and not so dirty, put those 6 bytes into 3 words and compare those 3 words the same way as above.
    I don't know why you're against comparisons. PBP supports them just fine.
    I would for sure compare the whole number. Leave just a fraction of room for
    Murphys' Law to creep in, and it does...;o}
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Lancashire
    Default Thanks
    Hi All
    I`m not so much against comparisons just looking for the smallest way to implement this. I shall give this more thought and see what I can manage. Certainly adding the total is a good quick and dirty method, I`ll look at this first.
    Cheers Pete
    Aug 2010
    Default i have a question
    can you please tell me how to compare 2 word in picbasic ??
    Look in the manual under sections
    4.18 Comparison Operators
    and
    4.19 Logical Operators.
    Aug 2010
    Default help please
    i have finish a temperature regulator system with rs232 serial port
    to finish the project i have to create a interface for real time mesurement of the temperature
    Can somebody give a interface (GUI )maltab or other php with a code for reading from the port rs232 reading
    the temperature >>>>>thank you
    barcosta , Why don't we just do the project for you? It's one thing to ask for help, and another to ask for the code....
    What are YOU learning?
  1. Using Nokia LCD
    By BobP in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2018, 04:47
  2. Read/Write Problem
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 10th February 2010, 01:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    By Don Mario in forum mel PIC BASIC Pro
    Last Post: - 28th November 2004, 23:56
