Weird Problem
Results 1 to 10 of 10
Thread: Weird Problem
    brighton
    Exclamation Weird Problem
    Hi All
    i have being experiencing this weird problem with my circuit and for the life of me i just cant get my head round it.
    i have a simple potential divider circuit like this
    5V|---------/\/\/\/\------/\/\/\/\------GND
    10K X 20K pot
    i am trying to get 2.53V so when i power up the circuit and vary the pot i get the
    2.51v when i check it with a voltmeter
    Now here comes the problem , if i take the probe of the volmeter off from point X and put it back to the same point x the voltage drops to 2.34v
    and i have to adjust it up again with the pot .
    but again if i disconnect and reconnect the voltage drops again.
    i havedone this about 20 times is there something weird going on here ?
    Isaac
    brighton
    Angry
    ..................10K.....X..... 20K pot
    What are you using for a power supply?
    brighton
    Thanks for your response its a Variable bench power supply 0-30V @ 1A
    Isaac
    If the power supply is stable, thought maybe you were using batteries, I will have to ask if there is a load on the divider.
    Other than that, I will have to guess that the pot becomes unstable with a little heat.
    Why not use fixed resistors?
    skimask's Avatar
    skimask Guest
    And it's a 20K pot! I'd bet a bump from the other end of the table would knock it out of whack.
    Try a smaller value pot.
    isaac, The maximum recomended input impedance for all Microchip Processors is 10K....
    brighton
    its not for the input the pic
    but i suspect its got to be the pot would try a lower vaue like 12k
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by isaac View Post
    Same thing most likely applies. Lower the values of the resistors.
    Daves' suggestion of using a fixed resistor is good too. I would replace at least one pot
    with a fixed 1%, and if using an A/D input to read this I would drop the pot to around 5K
    with the fixed value set to limit total current.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Weird code problem
    By Navaidstech in forum mel PIC BASIC Pro
    Last Post: - 16th March 2009, 11:16
  2. PIC18F got some weird problem?
    By NatureTech in forum mel PIC BASIC Pro
    Last Post: - 19th February 2007, 16:18
  3. Weird Oscillator Problem
    By eoasap in forum mel PIC BASIC Pro
    Last Post: - 17th December 2005, 14:21
  4. Weird problem with 12F629
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 28th May 2005, 07:15
  5. weird 12F629/675 problem
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 7th October 2004, 01:08
