Hello Frozen001,
Without seeing the code, or knowing the PIC you are using . . .
Probably the main OSC is not working, and it is running on backup OSC I. E. FSCM
Fail Safe Clock Monitor, likely your friends code has no config fuses set and they did that manually in the programmer
