Access array in PBP and .asm
Results 1 to 6 of 6
    Nov 2004
    Default Access array in PBP and .asm
    Hi Folks,
    I'm working on a project where I'm simultaneously receiving, manipulating, and transmitting serial data. This data comes and goes in 64-byte chunks.
    I'd like to set up an interrupt routine in assembly language to receive the data, and then use PBP to handle the rest of the functionality.
    Serial reception will be through the chip's UART (an 18F part) and transmission will be done in software. The incoming and outgoing baud rates are wildly different, so I can't just use the TX side of the same UART.
    Nor can I receive a packet, reset the UART to a different baud rate and then retransmit, as I'll miss critical incoming data.
    Therefore, the transmit and receive threads need to run concurrently and independently.
    Here's the question:
    If I define an array in PBP like this:
    DataIN VAR byte[64]
    how do I access it from within the .asm routine?
    I'm sure it's not difficult, but I can't quite wrap my brain around it.
    I know that a single PBP variable Foo can be accessed as _Foo in assembly. But how does it work with an array?
    JEC
    Already done for you http://www.melabs.com/resources/samp...p/serbufAx.bas
    Just change the buffer size & tweak to your specs.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Nov 2004
    Don't know how I missed that in my searching.
    Many thanks, Bruce. That looks perfect.
    Hi John,
    One problem that you will probably have is in trying to send serial data using SEROUT(2).
    Those commands are timed by software, which will be continuously interrupted by the USART RX handler, which throws off the baud rate.
    A possible solution can be found here ...
    http://www.picbasic.co.uk/forum/showthread.php?p=53931
    It uses a Timer as the baud rate generator, which overcomes the software timing problems.
    HTH,
    Sep 2005
    Campbell, CA
    Could you possibly use a PIC with two hardware UARTS? That would make things *so* much easier.
    Charles Linquist
    Nov 2004
    Actually, that's the part I didn't mention. I'm looking at the 18F6310, which appears to be only a couple dollars. Unless I've missed something, that's the smallest of the 18Fs with two ports, and it comes in a 64-TQFP package.
    It has two hardware ports and two separate interrupt generators.
    However, the ability to receive data into an array in the .asm routine is still very desirable. I can do my array massaging in the main program, then dump it out the door.
    Darrel's link above describes some neat tricks too.
    The depth of knowledge & willingness to share on this board is always amazing. Thanks to all who have taken a moment to reply.
  1. ASM code
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 2nd March 2010, 00:55
  2. PBP 2.6/MPLab 8.33 ASM "COD" error message
    By reddog24 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2009, 21:09
  3. Tracing & Stepping: PBP & MPLAB
    By chicowoodhill in forum mel PIC BASIC Pro
    Last Post: - 7th September 2008, 02:23
