Code Timer - How long does it take to execute XYZ command?
Results 1 to 6 of 6
    May 2006
    Del Rio, TX, USA
    Default Code Timer - How long does it take to execute XYZ command?
    Since this question has come up again, I thought I'd throw this module out to the masses. It is something I worked on a while back, with DT's help. Amid life's other priorities, it got put on the self to collect dust.
    The basic idea is that by adding the module as an INCLUDE and inserting a couple of commands inside your code, you can have the PIC send timing data to your PC via the hardware serial port. It's make for 18F PICs (although some 16Fs may work too). You also need a timer that is not being used for anything else.
    1) Instructions are included, as well as a small example.
    2) It worked well for me, and as I recall, DT in testing.
    3) Use it however you want.
    4) I won't be able to offer much support, but figure there are enough knowlegeable folks around here that can help those who need it.
    Best Regards,
    SteveB
    Thanks Darrel for all your help!
    Thumbs up
    Quote Originally Posted by SteveB View Post
    Yes it did.
    Much better than mine ever was.
    And I gotta say, much prettier than any of mine too.
    Just love the look of it. Nice work Steve.
    <br>
    Thanks SteveB.
    I bet this thread will get pointed to a lot.
    May 2006
    Del Rio, TX, USA
    <br>
    I used this program for the ...
    <pre><font face=courier> _ ____ ____ ___ ___ _ _ _____ _<br> / \ / ___| / ___|_ _|_ _| / \ _ __| |_ |_ _|____ _| |_<br> / _ \ \___ \| | | | | | / _ \ | '__| __| | |/ _ \ \/ / __|<br> / ___ \ ___) | |___ | | | | / ___ \| | | |_ | | __/> <| |_<br> /_/ \_\____/ \____|___|___| /_/ \_\_| \__| |_|\___/_/\_\\__|<br></font></pre>
    Lots of fonts, but the more plain ones seem to be the most readable.
    SteveB
    Last edited by SteveB; - 10th August 2008 at 14:51. Reason: Hee, Hee, Hee.. nice trick DT!
    <pre><font face=courier> _____ _<br> / ____| | |<br> | | ___ ___ | |<br> | | / _ \ / _ \| |<br> | |___| (_) | (_) | |<br> \_____\___/ \___/|_| _ _<br> |__ __| | | | | |<br> | | | |__ __ _ _ __ | | _____| |<br> | | | '_ \ / _` | '_ \| |/ / __| |<br> | | | | | | (_| | | | | <\__ \_|<br> |_| |_| |_|\__,_|_| |_|_|\_\___(_)<br></font></pre>
    Huntsville, AL
    Thanks! I'm at work and haven't gotten a chance to try it yet, but I noticed you said it would work for "some" 16F chips. Would a 16F628a be included in that group?
    Thanks again!
  1. decoding quadrature encoders
    By ice in forum mel PIC BASIC Pro
    Last Post: - 28th February 2017, 10:02
  2. Elapsed Timer Demo
    Last Post: - 29th October 2012, 18:39
  3. Making Program Code Space your playground...
  4. Interrupt/timer not really interrupting...
    Last Post: - 22nd May 2005, 23:05
  5. Timer Accuracy
    By GEEZER in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 06:26
