TTL magnetic card reader interface ith PC
Results 1 to 4 of 4
    Jul 2008
    Default TTL magnetic card reader interface ith PC
    Hi al!
    I want to interface TTL magnetic card reader with PC via PS/2 Keyboard port
    the card reader i m using is Tysso TTL MCR series which reads data from track 2,
    the reader operates at 5 VDC & there are three more pins which are CARD PRESENT.
    CLOCK & DATA. I have tried it with directly connected the data & clock signals to PS2
    Keyboard port but it does not work out is there any other way to make it compatible with PS2 as i have heard that it shows the data content directly on note pad when card
    is swiped.
    Below is the datasheet of the card reader i m using.
    http://www.barcode-manufacturer.com/...ification.html
    Thanks.
    skimask's Avatar
    skimask Guest
    Have you tried a search on "magnetic card reader" yet?
    http://www.picbasic.co.uk/forum/showthread.php?t=1742
    Jul 2008
    Yes i have search out some data but not exactly got it, there a keyboard wedge technique
    which is like, the keyboard & card reader both connected simultaneously the keyboard inputs the card reader & card reader output at PS2 keyboard port but still missing what will
    be the circuitry for this task.
    Feb 2016
    Default Re: TTL magnetic card reader interface ith PC
    Quote Originally Posted by attabros View Post
    Hi, you can take a look at Syncotek SC-750, it is one TTL card reader with RS-232 interface, baud rate adjustable; USB port and TTL at optional.
    Hope this helps!
  1. parallax rfid reader module interface with PC
    By jonil22 in forum Off Topic
    Last Post: - 3rd February 2008, 07:54
  2. Parallx rfid reader module interface with PC
    By jonil22 in forum mel PIC BASIC Pro
    Last Post: - 31st January 2008, 09:50
  3. Magnetic Card Reader
    By humex in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 05:57
  4. Smart card reader with PIC16F84A
    By bangunprayogi in forum Serial
    Last Post: - 12th August 2005, 11:36
  5. Reading Magnetic Card on Pic16f876
    By Finn in forum mel PIC BASIC Pro
    Last Post: - 5th February 2004, 00:36
