Interfacing GPS receiver module with PIC16F876
+ Reply to Thread
Results 1 to 5 of 5
    theblackhourse's Avatar
    theblackhourse Guest
    Default Interfacing GPS receiver module with PIC16F876
    hi all
    iam trying send an sms containing the GPS coordinates by connecting both using
    pic 16f876 i found the circute and the code but it steel not working and i really don't know why.i have tryed all the AT commands on the hyperterminal and it is working good.that is the circuit and the code.
    below the code and the circuit
    define OSC 20
    device 16f876a ,hs_osc,wdt_off, BOD_ON, pwrt_on, lvp_off, protect_on
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_SPBRG 64
    DEFINE HSER_CLROERR 1
    Led1 var portb.6
    Led2 var portb.7
    GPS var portb.4
    high Led1
    high Led2
    counter1 var byte
    dim RX[64] as byte
    dim TX[21] as byte
    dim charcount as byte
    dim txcounter as byte
    dim rxcounter as byte
    dim temp1 as byte
    dim temp2 as byte
    RX[1]="$"
    RX[2]="G"
    RX[3]="P"
    RX[4]="R"
    RX[5]="M"
    RX[6]="C"
    RX[7]=","
    '131532
    RX[14]=","
    'A
    RX[16]=","
    '3048.34
    RX[24]=","
    RX[26]=","
    RX[35]=","
    RX[37]=","
    RX[43]=","
    RX[49]=","
    RX[56]=","
    RX[62]=","
    COUNTER1=0
    PAUSE 2000
    CHECKMOBILE:
    hserout ["at",13]
    hserin 1000,checkmobile,[wait("ok")]
    low Led1
    mainloop:
    high Led2
    serin2 GPS,188,[wait("RMC,"),RX[8],RX[9],RX[10],RX[11],RX[12],RX[13],_
    wait(","),RX[15],_
    wait(","),RX[17],RX[18],RX[19],RX[20],RX[21],RX[22],RX[23],_
    wait(","),RX[25],_
    wait(","),RX[27],RX[28],RX[29],RX[30],RX[31],RX[32],RX[33],Rx[34],_
    wait(","),RX[36],_
    wait(","),RX[38],RX[39],RX[41],RX[41],RX[42],_
    wait(","),RX[44],RX[45],RX[46],RX[47],RX[48],_
    wait(","),RX[50],RX[51],RX[52],RX[53],RX[54],RX[55],_
    wait(","),RX[57],RX[58],RX[59],RX[60],RX[61],_
    wait(","),RX[63]]
    low Led2
    For Counter1 = 1 To 40
    Toggle led2
    Pause 100
    Next
    Low Led2
    Pause 1000
    send:
    Txstatus2:
    HIGH led1
    hserout ["AT",13]
    HSerin 1000,Txstatus2,[wait("ok")]
    Low Led1
    Counter1 = 0
    txstatus3:
    High Led1
    HSerout ["AT+CMGS=140",13]
    HSerin 1000,txstatus3,[wait(">")]
    LOW Led1
    Pause 500
    transmit3:
    high Led1
    HSerout ["0011000a8110121723750000aa3f"]
    charcount = 1
    FOR Counter1 = 1 TO 8
    txcounter = 0
    '______________________________
    TX[txcounter] = rx[charcount]
    temp1 = tx[txcounter]
    charcount = charcount + 1
    Temp2 = RX [charcount]
    temp1.7 = temp1.7 OR temp2.0
    TX[txcounter] = temp1
    txcounter = txcounter + 1
    '_______________________________
    temp2 = temp2 >> 1
    temp1=temp2
    temp2 = RX[charcount]
    temp1.7 = temp1.7 OR temp2.2
    temp1.1 = temp1.6 OR temp2.1
    temp1.5 = temp1.5 OR temp2.0
    temp2 = temp2 >> 2
    temp1 = temp2
    temp2 = rx[charcount]
    temp1.6 = temp1.6 OR temp2.1
    tx[txcounter] = temp1
    temp2 = temp2 >> 3
    temp1 = temp2
    temp1.7 = temp1.7 OR temp2.3
    temp1.6 = temp1.6 OR temp2.2
    temp1.5 = temp1.5 OR temp2.1
    temp1.4 = temp1.4 OR temp2.0
    '_________________________________
    temp2 = temp2 >> 4
    temp1 = temp2
    temp1.7 = temp1.7 OR temp2.4
    temp1.6 = temp1.6 OR temp2.3
    temp1.5 = temp1.5 OR temp2.2
    temp1.4 = temp1.4 OR temp2.1
    temp1.3 = temp1.3 OR temp2.0
    '__________________________________
    temp2 = temp2 >> 5
    temp1 = temp2
    temp1.7 = temp1.7 OR temp2.5
    temp1.6 = temp1.6 OR temp2.4
    temp1.5 = temp1.5 OR temp2.3
    temp1.4 = temp1.4 OR temp2.2
    temp1.3 = temp1.3 OR temp2.1
    temp1.2 = temp1.2 OR temp2.0
    temp2 = temp2 >> 6
    temp1 = temp2
    temp1.7 = temp1.7 OR temp2.6
    temp1.6 = temp1.6 OR temp2.5
    temp1.5 = temp1.5 OR temp2.4
    temp1.4 = temp1.4 OR temp2.3
    temp1.3 = temp1.3 OR temp2.2
    temp1.2 = temp1.2 OR temp2.1
    temp1.1 = temp1.1 OR temp2.0
    HSerout [HEX2 TX[0], HEX2 TX[1], HEX2 TX[3],HEX TX[4],HEX2 TX[5],HEX2 TX[6]]
    NEXT
    HSerout [26]
    low Led1
    Pause 60000
    GOTO mainloop
    skimask's Avatar
    skimask Guest
    For one thing, you're using both HSERIN and SERIN. Which is it? Can't really have both without resetting the serial port pins back and forth between the serial module and general purpose I/O.
    And, 2nd, you do realize this is a PicBasicPro forum, not a Proton Basic forum, right? PicBasicPro doesn't do DIMs and I'm not sure, but I don't think Proton does PAUSE.
    So, again, which is it?
    Default GPS fields can be variable length
    I am not sure you can use the explicit array approach (Rx[26] = "," etc) as the NMEA sentences are variable length and what might be a comma this time may not be a comma when the field data changes.
    I posted code to decode/parse GPS sentences a year or two back.
    Have a look at:-
    http://www.picbasic.co.uk/forum/show...ghlight=parser
    HTH
    BrianT
    theblackhourse, This section of code does not look right...
    temp2 = temp2 >> 1
    temp1=temp2
    I beleive the line "temp1.1 = temp1.6 OR temp2.1" should be "temp1.6 = temp1.6 OR temp2.1" Also I think with a little thought you can get this series of lines down to about 10 or so...
    Jan 2013
    Default Re: Interfacing GPS receiver module with PIC16F876
    How are you getting on with your tracker project?
    Camerart
  1. Replies: 0
    Last Post: - 17th June 2009, 03:55
  2. Replies: 1
    Last Post: - 27th July 2008, 06:14
  3. Replies: 4
    Last Post: - 15th May 2008, 09:43
  4. interfacing gps receiver with 16f877a
    By sakhyvava in forum GPS
    Last Post: - 27th September 2006, 09:13
  5. GPS Receiver
    By lester in forum Adverts
    Last Post: - 22nd February 2006, 12:47
