About writing word variables into the eeprom
Results 1 to 12 of 12
    Ted's's Avatar
    Ted's Guest
    Default About writing word variables into the eeprom
    I had the challenge to write a word-array into the eeprom of a 16f628a. And if I am well informed only values from 0 to 255 fit into one "cell" of the 128 cells this pic offers.
    I did it this way:
    counter = 0
    arraysize = 20
    FOR ArrayPosition = 0 TO arraysize-2 STEP 2
        Word_Dummy = Array[counter]
        WRITE ArrayPosition,Word_Dummy.Byte1
        counter = counter + 1
    Next ArrayPosition
    counter = 0
    FOR ArrayPosition = 1 TO arraysize-1 STEP 2
        WRITE ArrayPosition,Word_Dummy.Byte0
    Next ArrayPosition
    Is there a more efficient way?
    Bombay, India
    Since you're dealing with word variables, the size is known to be 2bytes on the PIC. So, something like this will work
    SaveArray:
    FOR ArrayPosition = 0 TO 20-1
        WRITE ArrayPosition*2,Array[ArrayPosition].Byte0,Array[ArrayPosition].Byte1
    Next
    ReadArray:
        READ ArrayPosition*2,Array[ArrayPosition].Byte0,Array[ArrayPosition].Byte1
    Next
    Ted's's Avatar
    Ted's Guest
    I disagree here.
    is for ArrayPosition = 0
    WRITE 0,Array[0].Byte0,Array[0].Byte1
    is for ArrayPosition = 19
    WRITE 38,Array[19].Byte0,Array[19].Byte1
    According to the manual, to write a word, each of the 2 bytes that make up the word must be written separately:
    w Var Word
    WRITE 0,w.BYTE0
    WRITE 1,w.BYTE1
    in other words, WRITE does not accept 3 arguments.
    Bombay, India
    Ted, you're right on this. I goofed. But you got the idea though
    Ted's's Avatar
    Ted's Guest
    Yes. But it does not seem to be efficient enough.
    A one or two-liner should be enough. Maybe using the remainder // ?
    When you say efficient, do you mean speed or code size?
    If you alias the Word array as a Byte array, you can just write 1 byte at a time in the loop.
    arraysize  CON 20
    Array      VAR WORD[arraysize]
    @ByteArray = _Array
    ByteArray  VAR BYTE EXT
    FOR ArrayPosition = 0 TO (arraysize*2-1)
        WRITE ArrayPosition, ByteArray(ArrayPosition)
    NEXT ArrayPosition
    Ted's's Avatar
    Ted's Guest
    The latter.
    I've only done this once a while back but all I did in my program at WRITE time is:
    WRITE 0,X.BYTE0 : WRITE 1,X.BYTE1
    At READ time:
    READ 0,X.BYTE0 : READ 1,X.BYTE1
    I don't remember having any problems. Hope it works.
    Ted's's Avatar
    Ted's Guest
    It does.
    You know, the issue here is filling the eeprom with data from a word array. Your line is only a part of it.
    Ted's's Avatar
    Ted's Guest
    arraysize  CON 20
    @ByteArray = _Array
    NEXT ArrayPosition
    I do not understand your code. Please comment.
    This should help some.
    Once you know what the EXT modifier does, it should make more sense.
    The EXT (external) modifier.
    http://www.picbasic.co.uk/forum/showthread.php?t=3891
    <br>
  1. Read/Write Problem
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 10th February 2010, 02:51
  2. Minimizing code space
    Last Post: - 30th May 2009, 08:25
  3. DS2760 Thermocouple Kit from Parallax in PicBasicPro
    By seanharmon in forum mel PIC BASIC Pro
    Last Post: - 9th July 2008, 00:19
  4. calculation problem
    By nicolelawsc in forum mel PIC BASIC Pro
    Last Post: - 31st March 2006, 16:23
  5. word variable to 25lc640
    By TONIGALEA in forum mel PIC BASIC Pro
    Last Post: - 6th July 2004, 20:59
