+ Reply to Thread
Results 1 to 3 of 3
Thread: adcin reading
    Jun 2008
    Default adcin reading
    Hi guys I'm trying to read the voltage from a 12 v battery i have a perfect 3:1 voltage divider but i can't seem to get any accurate readings i think something is wrong with my formulas and i can't seem to grasp it. here is what i have so far if anyone can help.
    TRISA = %11111111
    TRISB = %00000000
    TRISC = %00000000
    DEFINE OSC 20
    DEFINE LCD_DREG PORTB 'LCD data port
    DEFINE LCD_DBIT 4 'LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTB 'LCD register select port
    DEFINE LCD_RSBIT 1 'LCD register select bit
    DEFINE LCD_EREG PORTB 'LCD enable port
    DEFINE LCD_EBIT 0 'LCD enable bit
    DEFINE LCD_BITS 4 'LCD bus size 4 or 8
    DEFINE LCD_LINES 2 'Number lines on LCD
    Define ADC_CLOCK 0 ' Set clock source
    Define ADC_SAMPLEUS 50' Set sampling time in uS
    ADCON1 = 142
    bat_volts var word
    Start:
    ADCIN porta.0, bat_volts
    bat_volts = (bat_volts */500)>> 2
    LCDout $FE, 1 , " Voltage In"
    LCDout $FE, $C0, " ", dec(bat_volts/100 *3),".",dec1 bat_volts, " V"
    pause 200
    goto start
    Dec 2005
    For starters...forget the formulas for just a little bit...look at raw numbers.
    Do the raw numbers make sense?
    For instance, if your Vref is 5v, and the Vin at the analog port is 2.5v, is the raw number 512 (for a 10 bit input) or 128 (for an 8 bit input) ?
    If those numbers make sense, then work on the formulas. If they don't, well, then you've probably got something else goofy going on...ports not set up right, TRIS not set right, input circuit not set up right...something...
    Some of the changes are marked in bold...some aren't...
    DEFINE OSC 20
    trisa=$ff:trisb=0:trisc=0:adcon1=142:bat_volts var word:raw_in var word
    Start: ADCIN porta.0, raw_in
    bat_volts = (raw_in */ 375)
    LCDout $FE, 1 , "Raw = ", DEC5 raw_in
    LCDout $FE, $C0, "Volts=", DEC2 (bat_volts/100),".",dec2 (bat_volts//100, " V"
    pause 200:goto start
    California
    Quote Originally Posted by mitchf14 View Post
    With ADC_CLOCK 0 (2TOSC), the maximum device frequency is 1.25 Mhz
    With a 20 Mhz OSC, you need to use ADC_CLOCK 2, 6 or 3.
    2 is the fastest (32TOSC).
    hth,
+ Reply to Thread
  1. ADCIN Problem
    By JavPar in forum General
    Last Post: - 20th January 2009, 03:36
  2. ADCIN and PIC18F4331 Arghhhhh !
    By GrandPa in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 11:54
  3. Adcin or Pot
    Last Post: - 11th January 2007, 16:46
  4. ADCIN - AD settings are wrong
    By teverett in forum mel PIC BASIC Pro
    Last Post: - 4th December 2006, 16:32
  5. help using adcin
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 31st January 2006, 07:46
