Hi guys...
any ideas how to set this?
my pin assignments are:
RS PORTB.4
E PORTB.5
but the data lines are
PORTB.0 LCD D7
PORTB.1 LCD D6
PORTB.2 LCD D5
PORTB.3 LCD D4
and my code is...
The problem I have is the usual pin assignment isCode:DEFINE OSC 8 DEFINE LCD_DREG PORTB 'set LCD DATA port DEFINE LCD_DBIT 4 'set starting DATA bit (0 or 4) if 4-bit DEFINE LCD_RSREG PORTB ' Set LCD Register Select port DEFINE LCD_RSBIT 4 ' Set LCD Register Select bit DEFINE LCD_EREG PORTB ' Set LCD Enable port DEFINE LCD_EBIT 5 ' Set LCD Enable bit DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits) DEFINE LCD_LINES 4 ' 4 Line LCD LCD DEFINE LCD_COMMANDUS 2000 ' Set command delay time in us DEFINE LCD_DATAUS 50 ' Set data delay time in us
PORTB.0 LCD D4
PORTB.1 LCD D5
PORTB.2 LCD D6
PORTB.3 LCD D7
HOW do I set the fact the pins are "backwards"?
