Reading a SMS to an array
Results 1 to 4 of 4
    May 2008
    Smile Reading a SMS to an array
    Dear friends. I need some help reading a SMS into an array. I tried the below code but it doesn't seem to work properly.
    I am using harware interrupts to get into an interrupt routine when a SMS is received. I want to check for +CMTI: "SM" ,1 string and extract the SMS location to a variable called sms_location. Then I want to use AT_CMGR command to read that SMS location and put the receiving message into sms_array.
    hserin 1000, start, [wait("CMTI:"), skip 6, DEC2 sms_location]
    hserout ["AT+CMGR=", sms_location, 13, 10]
    hserin 1000, ff, [STR sms_array\100]
    Then I can parse the sms_array and remove all unnecessary data. The above code segment compiles but I it doesn't read the correct SMS location.
    instead if I replace the 2nd line above with
    hserout ["AT+CMGR=1", 13, 10]
    then it reads the SMS location 1 and puts the data to smsm_array nicely.
    I would appreciate any help from you nice people.
    Lancashire
    Hi
    Just a thought, I could be wrong.
    when you use hserin 1000, start, [wait("CMTI:"), skip 6, DEC2 sms_location, sms_location will contain a number, 2 digits say 01.
    I have a feeling that the modem will require it passed in ASCII and not in the form its in.
    when you do hserout ["AT+CMGR=1", 13, 10] I think it will send the 1 as ASCII $31 Decimal 49 and what your sms_location passes is ASCII char 11
    Cheers Pete
    May 2008
    Default Reading a SMS to an array
    Hi Pete,
    Thanks a lot for pointing it out. Yes you are right. I have changed the line to
    hserout ["AT+CMGR=", #sms_location, 13, 10]
    Now it sends ASCII and it works fine. !!!
    Kamal
    Lancashire
    Hi KA5MAL
    Glad to be of help!
    Cheers Pete
    Last Post: - 14th June 2016, 07:55
  2. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 04:46
  3. Replies: 11
    Last Post: - 19th August 2009, 15:23
  4. WRITECODE stores wrong 14-bit word values in FlashMEM
    By BobPigford in forum mel PIC BASIC Pro
    Last Post: - 26th June 2009, 04:35
  5. Reading Array values into variables
    Last Post: - 21st March 2005, 10:30
