+ Reply to Thread
Results 1 to 8 of 8
Thread: ICSP with EPIC
    Apr 2006
    Alberta Canada
    Default ICSP with EPIC
    i have an EPIC plus programmer that i use for ICSP. after i program, i need to disconnect the lines and then restart my board. is there something i can do so i can leave the programmer plugged in, so all i need to do is restart the board? or is there a way to make it automatically restart so i can program and have it run without disconnecting anything or cycling the power?
    Dec 2005
    Check the manual for the PICKIT2 (or most other programmers for that matter).
    You'll see that they show you how to hook up your programmer so you can leave it connected while doing a 'test run' on your circuit.
    You could still add a switch on the MCLR line... or a automated switcher... which will require some PC programming & interfacing.
    Tons of solutions here, depending how much time you want to spend on
    Please use code tag when you post a code here.
    [code] paste your code here [/code]
    Apr 2006
    Alberta Canada
    i looked at the PICkit manual, and all i saw was that they had the PGC and PGD lines isolated from the rest of the circuit with resistors. and the MCLR line has a diode on it to stop the high voltage from going into the rest of the circuit.
    in my circuit, the PGM, PGC, and PGD lines arent used for anything but programming.
    Dec 2005
    Quote Originally Posted by dragons_fire View Post
    That's what I was talking about. All you should have to do is maybe add a switch for MCLR. You have to keep the diode to keep from feeding the 12v back into the 5v pullup, the resistors, I'd keep them in there so you could, in theory, use RB6/RB7 later on.
    Try the switch on MCLR pin. Picstart had that 'problem'. I think my BK precision had this problem too... still not sure since i've made that automatic switcher interface...
    Dec 2005
    Got my own automatic switcher interface...called a PICKIT2...
    I agree, but in some circumstance it still load the pin a little bit.. enough to screw few things... on really specific things and design though. Good enough on 90% cases.. at least mine
+ Reply to Thread
  1. ICSP from EPIC to Breadboard && 16f88
    By rdxbam in forum General
    Last Post: - 14th December 2008, 20:13
  2. Replies: 1
    Last Post: - 10th December 2007, 23:57
  3. Need the programmer EPIC software
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2007, 11:42
  4. programming straight assembly with epic?
    By clr2cont in forum Off Topic
    Last Post: - 2nd March 2007, 15:12
  5. EPIC 2.46 beta and 16f876a-i/sp
    By andyf97 in forum mel PIC BASIC Pro
    Last Post: - 11th October 2005, 11:49
