Do READ and WRITE for PIC16F690 onboard EEPROM need 10ms pause?
Results 1 to 5 of 5
    xnihilo's Avatar
    xnihilo Guest
    Smile Do READ and WRITE for PIC16F690 onboard EEPROM need 10ms pause?
    Do I need to add a 10ms pause after a READ or WRITE to the onboard EEPROM in a PIC16F690?
    I could not fine any info about that in the PBP manual or in the datasheet of this PIC.
    Thanks!
    Quote Originally Posted by xnihilo View Post
    Thanks!
    How many times are you going to post the same basic question?
    xnihilo's Avatar
    xnihilo Guest
    Angry
    One is about the internal eeprom, the other one is about an external EEPROM chip.
    READ or I2CREAD does not need a pause - ever. Whether it is external or internal EEPROM it does not matter.
    WRITE (for internal EEPROM) does not need a pause as it is handled already by PBP.
    I2CWRITE however DOES need a pause because PBP does not know if you are writing to an EEPROM or some other I2C device. Check with your external I2C devices Datasheet to see what your pause (if any) should be.
    xnihilo's Avatar
    xnihilo Guest
    Thank you very much, now I know.
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 14:19
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 19:59
