How to select timeout related to buadrate for HSERIN ?
Results 1 to 4 of 4
    Default How to select timeout related to buadrate for HSERIN ?
    Please help, Thanks in advance.
    Are you meaning the timeout option if a signal is not present?
    If so, the baud rate does not matter.
    Or are you looking for how to use an interrupt with HSERIN?
    Yes.
    Cause some of my application at buad rate 115,200 , I chose timeout = 2mS and 100mS.
    Some of data overlap when timeout is different.
    For interrupt, I ever tried but it's not working fine (may be I not really understand for USART interrupt).
    Post the offending code here, interrupt are not as this complicated... but most of us have been afraid to use them before understanding them, now that we understand... it's something we can't remove of most/all our stuff/suggestions
  1. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 09:10
  2. A little DTMF help
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2006, 02:31
  3. select case question
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 12th March 2006, 11:01
  4. Select Case syntax
    By keithdoxey in forum mel PIC BASIC Pro
    Last Post: - 27th September 2005, 20:19
  5. Interrupt/timer not really interrupting...
    Last Post: - 22nd May 2005, 23:05
