LCD and PIC18F2685 - Weird LCD behavior
Results 1 to 6 of 6
    Apr 2008
    Berlin, Germany
    Default LCD and PIC18F2685 - Weird LCD behavior
    I'm using the 28 pin demo board from Microchip (see schematic below) with a 18F2685pic, MPLAB IDE and Picbasic pro v2.47, and ICD2 for programming. The LCD pins are connected in the default manner. I'm using the internal oscilator @8 MHZ and the config file in my pbp directory is modified accordingly, that is:
    __CONFIG    _CONFIG1H, _OSC_IRCIO67_1H
    The behavior the LCD is experiencing is bizzare: First, it shows black boxes on the first line (so everything fine until now). When releasing from reset, still black boxes on the first line. If I take LCD's Vdd out for a second I start seeing weird characters. Plug it back in, weird characters again. When I try to output "123456789" I get "1230123"(that is, with the vdd plugged in). If I try to output "hello", werid characters again.
    Some of the pins on the demo board are occupied with the default components(leds, pot) but I tried to stay away these pins. Just RB3 (LCD E(nable) is on the same pin as one of the board's LED)
    and the code:
    ' display a message on the lcd
    DEFINE OSC 8
    DEFINE LCD_DREG PORTB ' portb is the port used for data lines
    DEFINE LCD_DBIT 4		'the pin on port connected to LCD pin DB4
    DEFINE LCD_RSREG PORTA	'pic port used for the RS line
    DEFINE LCD_RSBIT 4		' port pin where RS pin is connected
    DEFINE LCD_EREG PORTB	' PIC port where E pin is connected
    DEFINE LCD_EBIT 3		' port pin where E pin is connected
    DEFINE LCD_BITS 4		' 4 bit mode
    DEFINE LCD_LINES 2		' 2 LCD lines
    DEFINE LCD_COMMANDUS 2000	'delay between LCD commands
    DEFINE LCD_DATAUS 50		'delay between data sent
    adcon1=7
    trisb=0 				' port b all outputs
    trisa=0					' port a all outputs
    intcon2.7=0			'enable pull ups
    OSCCON = %01110000
    '---main program
    repeta:
    high portb.0   ' light led to see when main loop is running
    LCDOUT $fe,1           ' Clears LCD
    LCDOUT $fe,2, "hello"  ' Returns to beginning of line 1 and writes "string"
    goto repeta
    The lcd is a optorex dmc16207 which is Hitachi HD44780 compatible
    skimask's Avatar
    skimask Guest
    Try this:
    DEFINE OSC 8
    adcon1=7:trisb=0:trisa=0:intcon2.7=0:osccon=$70
    PAUSE 1000
    repeta:
    high portb.0:LCDOUT $fe,1,$fe,2, "hello":pause 1000:goto repeta
    Apr 2008
    Berlin, Germany
    Thanks skimask for the suggestion but unfortunately the output is still the same. Initially black boxes. On "release from reset", still black boxes. If I pull out the LCD Vdd - strange characters, plug it back in, I get character boxes filled with strange characters corresponding to the number of characters I output with LCDOUT and a blinking cursor at the end.
    ADCON1 must be = $0F. If =7 AN9 is still analog.
    If you still have problem copy ALL your CONFIG fuse settings here.
    skimask's Avatar
    skimask Guest
    Which would likely account for the "0123456789" vs. "012301230" error noted in the 1st post.
    Good call...
    Apr 2008
    Berlin, Germany
    Eventually I moved the data lines on PORTC and voila, the LCD is displaying characters as it should. Thank you guys for the help.
    Here is the working code:
    '--- defines
    DEFINE OSC 8
    DEFINE LCD_DREG PORTC ' portb is the port used for data lines
    '--- register configs
    adcon1=$0F ' all digital i/o
    trisb=0		' portb all outputs
    trisa=0		'porta all outputs
    trisc=0
    intcon2.7=0	' enable pullups
    osccon=$70	' oscilator configure
    '--- main program
    PAUSE 1000				' pause to let the LCD initialise
    repeta:
    LCDOUT $fe, $C0, "world"    ' line 2
    pause 1000				' pause to see it
    goto repeta				' do this forever
