+ Reply to Thread
Results 1 to 24 of 24
Thread: Need some advice.
    Apr 2008
    Default Need some advice.
    Hi everyone, I'm building a device which controls temperature. Currently I'm using an 18b20 to pick up the temperature and I also have to detect zero crossing on a 50hz ac waveform on portb.0 so I can fire a triac on cirtain 0-10ms periods. I'm using a 16f628 at 4meg. it is critical that the phase controling is not interupted while gathering the temp from the 18b20 however I'm having trouble due to the time being needed to access the temperature. Does anybody know if it is at all possible to do this using the interupt on portb.0 or am I just barking up the wrong tree using this 18b20 or should I use something like a 16f88 and an lm35 with some kind of voltage ref? thanks in advanced
    Le Treport 76 FRANCE
    Wink
    No problem ... just poll the DS data line to see if conversion has ended.
    ' Start temperature conversion
    mainloop: OWOut DQ, 1, [$CC, $44 ]
    ' Check for still busy converting ( ~ 4500 fois ... )
    waitloop:
    		INPUT DQ
    		If NOT DQ Then waitloop
    ' Read the temperature
    	OWOut DQ, 1, [$CC, $BE ]
        OWIn DQ, 0, [temperature.LOWBYTE, temperature.HIGHBYTE, Skip 4, count_remain, count_per_c]
    Here, you won't have a Waitloop, but, say, goto your regulating loop ...
    AND remember heating has "a little" ( LOL !!! ) inertia, and some AC periods more or less won't disturb the system ...
    the temp data will be updated each ~ .75 s ... that's all !!!
    using a MOC 3041 to drive your SCR could miraculously simplify your program ...
    just an idea ...
    Jan 2006
    Istanbul, The Only City and The Only Place That Connects Two Continents
    From my side, I can say couple of things.
    1. If the temp resolution (and consistency) IS NOT very critical, then you can use LM35 with 12F675, and if only turn ON/OFF is on the subject (no voltage control) then you can directly fire the triac from PIC pin using zero-crossing.
    2. If temp resolution (and consistency) is critical then you can use DS18B20 with 12F675 and fire the triac from PIC pin using zero-crossing. You can check the "busy" feature so that you do not wait for temp conversation.
    In both cases, sensitive gate triacs will be more suitable for PIC's current sink (25mA max).
    If you use regular triacs, then gate will draw about 35mA, thus a MOC type will be appropriate as Alain mentioned.
    "Young guys communicate a lot more than we used to. Maybe the quality is a little bit lower because the quantity is simply huge."
    Apr 2008
    thanks for your reply s. here is a piece of software I'm using just to see if I can get it working without the flicker of when temp hits 5000 and 10000, so far failed, I'm using a moc 3021 and a bt137 and bridge with a 1k feeding porta.0 and a 10k holding it low. I have been able to make a simple dimming program so I know this hardware works, I also have an lcd so I need a few more io that a 12f675
    Define LCD_DREG PORTB
     'Set starting data bit
     Define LCD_DBIT 4 'rb4,rb5,rb6,rb7
     'Set LCD RS Port
     DEFINE LCD_RSREG portb
     'Set LCD RS Bit
     define LCD_RSBIT 3
     'Set LCD Enable Port
     Define LCD_EREG portb
     'Set LCD Enable Bit
     Define LCD_EBIT 2
     'Set number of LCD Lines
     Define LCD_LINES 2
     'Set Command Delay time in uS
     define LCD_COMMANUS 2000
     'Set Data delay time in uS
     define LCD_DATAUS 50
    temp var word
    temp = 0
    temp2 var word
    target var word
    target = 3000
    symbol fire = portb.1
    symbol ac = portb.0
    maxdelay var word
    maxdelay = 8000
    delay var word
    delay = 4000
    trisa = %00000011
    trisb = %00000001
    DQ	VAR	PORTa.0			' One-wire data pin
    temperature VAR	WORD			' Temperature storage
    count_remain VAR BYTE			' Count remaining
    count_per_c VAR	BYTE
    DS18B20_9bit CON %00011111 ; 93.75ms, 0.5°C
    DS18B20_10bit CON %00111111 ; 187.5ms, 0.25°C <-- My favorite
    DS18B20_11bit CON %01011111 ; 375ms, 0.125°C
    DS18B20_12bit CON %01111111 ; 750ms, 0.0625°C (default)
    OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_11bit]
    lcdout 254,1
    on interrupt goto firetriac
    intcon = %10010000
    mainloop:
    for temp = 0 to 10000
    if temp = 5000 then
    gosub startcon
    if temp = 10000 then
    gosub readtemp
    next temp
    goto mainloop
    disable
    firetriac:
    pauseus  delay
    fire = 1
    pauseus 10
    fire = 0
    intcon.1 = 0
    resume
    enable
    startcon:
    OWOut DQ, 1, [$CC, $44]       ' Start temperature conversion
    readtemp:
    waitloop: OWIn DQ, 4, [count_remain]	' Check for still busy converting
    	IF count_remain = 0 Then mainloop    'was this what you ment about no waiting in the 'loop
    	OWOut DQ, 1, [$CC, $BE]		' Read the temperature
    	' Calculate temperature in degrees C to 2 decimal places (not valid for negative temperature)
    	temperature = (temperature >> 1)
    	lcdout 254,1, dec temperature / 10 ,".", dec1 temperature , " c"
        lcdout 254,192, dec delay
    Apr 2008
    what I want to do over all is to dim an incandescent light depending what temperature it is without an annoying flicker while fetching the temp.
    You may try to switch to asm interrupt or Darrel's instant interrupt to see if it works better.
    A real schematic would help...
    To generate 10uSec with PAUSEUS, you need at least a 10MHz crystal. If you're using a 4MHz, you'll need to use asm NOP or GOTO
    A scope is handy for those things. 1 channel on the Main AC, the other on the PIC output... now you see if you're really in-synch. Be careful if you do that, unless we might see some smoke messages
    Please use code tag when you post a code here.
    [code] paste your code here [/code]
    Apr 2008
    my interup seems to work fine it just that the owin owout commands seem to really take alot of time and the interupts are missed in the process. i'll try to draw up a schematic.
    Apr 2008
    here is a quick diagram, I know thats not a moc3021
    Apr 2008
    here abit smaller
    Attached Thumbnails Attached Thumbnails Click image for larger version
    Quote Originally Posted by cphillips82 View Post
    This is why i've suggested to use Darrel's instant interrupts
    Talking Why making it simple ???
    The MOC 3041 ( and not 3021 ...) permitted to avoid all the zero detection AND the interrupts ...
    burst mode is really not a problem with heating systems ...
    Apr 2008
    Angry
    not too sure what you mean "burst mode" is that like on 1 sec off 4 secon = 20% heat?. I'll try instant interupt but I'm a little affraid of asm..... I hate it!
    Apr 2008
    and let the fun begin! can somebody tell me what error: variable wsave3 request 416 beyond ram_end 79 means? I have 3 errors like this in my first attempt at compiling. I installed mpasm and the include files for instant interupt.
    this is it ... in the end BUT, exactly ... the half waves are "full" , THANKS to the MOC 3041.
    for your example you will have 100 half waves ON ( always an integer ! ) @ 50 Hz = 1s followed by 400 "half waves OFF" @ 50 Hz = 4 sec ...
    as the DS1820 needs ~ 750 ms for conversion, just fix your regulator period to 1 sec ( in your example .2sec ON and .8 sec OFF ) and you'll have a .5% resolution in power ...
    far more than you need ... but very easy for your regulating soft calculations.
    Jan 2006
    Why not just skip the busy state of the temp conversation??
    If the temp conversation is in progress, do not wait, just pass it.
    Wink
    Hi, Sayzer
    WHILE temp conversion ...
    REGULATOR loops ...
    of course !
    just have to verify that the Process time. constant is 10 times or more the sensor time constant ...
    If you want it to look at, I committed sometimes ago a DS 1820 temp regulator : a R/C servo drives air flow section to cool some heating stuff ...
    Let's say it is intended to control the air flaps of a model "Corsair F4U " engine cowling ...
    Apr 2008
    thanks for you suggestion acetronics but burst will not work for me, I really need to regulate via dimming an incandescent bulb so it is not switching on and off all the time annoying eyes. I have checked only sending a
    yet this still makes a flicker which tells me that my interupt is not being seen while sending this message. does anybody know or can work out how long this command takes so I may be able to time when to send it?
    Wink
    when sending this line ... it just tell the DS to do it's measurement.
    what takes time is wait for the DATA line to come back high ...
    you can do other things just past this line ... PbP doesn't poll the line or insert a Pause "by itself " to let you do what you want during the conversion time.
    some MPLAB "stopwatch" to justify it.
    Owout $CC,$44 ... 473 µs @ 4 Mhz
    $CC,$BE ... id !!!
    Owin.. ... 1140 µs ( read result )
    will be difficult not to see "something" happens when "talking" with the DS ...
    I remember having soldered a an Incubator regulator with a single TDA 1023 ... which has a voltage setpoint input.
    The pic could make the temp measurement, drive alarms (?), convert digital setpoint ( a simple R/2R ladder as a DAC will be enough ) to an analog setpoint , and drive a cute viewing LCD display panel ...
    can of course being done with a Pic, but some trickery will be compulsory to place the different DS commands in the cycle time ...
    Apr 2008
    Thumbs up
    I love IT! This chip rocks, so an input voltage = output duty cycle. Is that right in simple terms? I'm going to study this data sheet. thanks for the suggestion!
    Clint
    Wink
    You also may download the TCA 785 or TDA 1185 Datasheets ... same kind of chips !
    PS : Do not forget the Lilly -of-the-valley !!!
    Apr 2008
    i'm going to take the approach of using an 16f88 with a tca785 using the onboard pwm so there are no timing issues while keeping the ds1820. what is the lilly of the vally?
    Apr 2008
    Befor I go on this venture.acetronic/thankyou!!!!!!1!!
    Wink
    " The Lilly of the Valley" ... is a nice little flower you are supposed to offer people you like, on the 1st of May ... as a lucky charm !!!
    I hope it's not only a French tradition ...
    Women do like you offer such nice flowers ...
    16F88 will be a bit overkill ( a 16F84 is enough ... LOL ! ) ... but you won't have "backfire" issues with this config. just don't forget an opto coupler for isolating the power section.
    IDEA !!! use "PWM", HPWM, or "SoftPwm" to issue yor required voltage ( will be the best solution for opto-coupler insulation ...)
    Maudit Francais! Yeah it seems to be an European tradition.
    Here we usually throw flower pot on the right edge of the head of someone we don't like
+ Reply to Thread
  1. Advice on Wiegand Buffer
    By brutc001 in forum Schematics
    Last Post: - 19th December 2009, 00:31
  2. Need "PIC16F84A" Controler schematic Advice...
    By Kyo_89 in forum Schematics
    Last Post: - 27th May 2009, 23:03
  3. Your OTP advice?
    By truvahorse in forum mel PIC BASIC Pro
    Last Post: - 28th June 2008, 16:37
  4. Decoding an incoming infrared signal: need advice
    Last Post: - 9th May 2008, 16:28
  5. Advice needed on 'neat' Project!
    By vacpress in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 06:21
