16F877A i/p interface with the gsm
Results 1 to 7 of 7
    matghonip's Avatar
    matghonip Guest
    Exclamation 16F877A i/p interface with the gsm
    someone plz help me.....
    i'm doing my final project,but i have some problem on interfacing the PIC16F877 with the gsm in oder to do the based sms system...
    someone if u have the best solution plz reply....
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by matghonip View Post
    {SIGH}
    Search this forum...plenty of finished examples that work just fine...
    T.Jackson's Avatar
    T.Jackson Guest
    {SIGH}
    I must be going blind -- for the life of me I can't find any.
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by T.Jackson View Post
    Maybe not 100%, ready to go, turnkey, out of the box, complete with wrapping paper and a pretty little bow on top...but...
    I get plenty of links and info in general on connecting to a phone and doing SMS in general, not only here but on Google.
    And the link in post #4...sure...it's not for an '877A. But most certainly, I think most would agree that an 'F72 is close enough to an '877A to make it work.
    Not only that, but if it's a FINAL project, I'd be willing to bet there would be some sort of instructor that SHOULD be knowledgable enough to help with the project, even if that help was only to point out links to reference material. If said instructor wasn't helpful enough to do even that, I'd wonder what sort of instructor would assign a project that would be an order of magnitude above his/her own skills.
    T.Jackson's Avatar
    T.Jackson Guest
    Lecturer interaction with assessments is not usually the case with many institutes. Normally you are expected to study the course material given to you, do the prac exercises and research this missing pieces on your own accord. If this fails then you seek private tuition.
    brighton
    It all depends on what gsm modem you are using.
    its easier to use a gsm modem than to use a mobile phone as not all mobile phones support Text mode which is easier to do than PDU
    Isaac
  1. Interface Pic --> Max232 --> GSM Modem
    By SangkiMangki in forum GSM
    Last Post: - 28th September 2013, 12:57
  2. Replies: 33
    Last Post: - 19th March 2010, 03:02
  3. problem with the GSM controller
    By Dariolo in forum mel PIC BASIC Pro
    Last Post: - 30th May 2009, 20:33
  4. i need information for GSM interface
    By m_vincent in forum GSM
    Last Post: - 30th January 2007, 15:48
  5. Replies: 0
    Last Post: - 25th November 2005, 14:35
