Help me in reading DATA from RFID 125KHZ tag reader
Results 1 to 4 of 4
    zeus's Avatar
    zeus Guest
    Default Help me in reading DATA from RFID 125KHZ tag reader
    Dear Members,
    I have a Philips P89C51RD2BN Microcontroller and a 125KHz RFID Reader from Sparr Electronics.The RFID reader just reads a tag and sent the TAG ID following a carriage-return/Line-Feed
    EX:'041201938C'(CR)(LF)
    I wrote a code so that the microcontroller reads the data from RFID reader via UART and checks the 7 byte of the data. But while debugging in the Keil compiler I can change the data for Sbuf. But the value is not assigned to any other variable or register.In this case to 'rfid' variable. Please help me in this problem.I have attached the code for your reference.
    My baud rate is 9600 and my mcu clock is 11.0592Mhz.
    #include(reg51.h)
    unsigned char rfid;
    void main(void)
    unsigned char i;
    TMOD=0X20;
    TH1=0XFA;
    SCON=0X50;
    TR1=1;
    while(1)
    while(RI==0);
    for(i=0;i<6;i++)
    rfid=SBUF;
    if(rfid==0x0b)
    P2^=0xFF;
    else if(rfid==0x08)
    P0^=0xFF;
    P2=0x04;
    RI=0;
    Talking Gods are fallen really low ...
    Hi
    1) You are aboard a MICROCHIP Pic Basic Forum
    2) You are aboard a Microchip PIC Basic Forum
    3) You are aboard a Microchip Pic BASIC Forum
    Bye-Bye ...
    skimask's Avatar
    skimask Guest
    Talking
    I don't understand.
    What do you mean by aboard?
    WOW! And not only that...But which PBP update supports 8051 MCU types?
    Bombay, India
  1. Using Nokia LCD
    By BobP in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2018, 04:47
  2. Read/Write Problem
    By Tobias in forum mel PIC BASIC Pro
    Last Post: - 10th February 2010, 01:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    By Don Mario in forum mel PIC BASIC Pro
    Last Post: - 28th November 2004, 23:56
