USB Keyboard how to make shift,ctrl,win,alt keypress,?
+ Reply to Thread
Results 1 to 4 of 4
    Jan 2008
    Default USB Keyboard how to make shift,ctrl,win,alt keypress,?
    I am attempting to implement a usb keyboard. This is a sample of project and it work. I send the letter "a" (small).
    My question is how to send big letter "A" with shift press?
    DEFINE OSC 48
    DEFINE LOADER_USED 1
    USBBufferSizeMax con 8 ' maximum buffer size
    USBBufferSizeTX con 8 ' input
    USBBufferSizeRX con 8 ' output
    ' the USB buffer...
    USBBuffer Var Byte[USBBufferSizeMax]
    USBBufferCount Var Byte
    I var byte
    TRISD = 255
    usbinit ' initialise USB...
    USBbuffer[0] = 0
    USBbuffer[1] = 0
    USBbuffer[2] = $04
    USBbuffer[3] = 0
    USBbuffer[4] = 0
    USBbuffer[5] = 0
    USBbuffer[6] = 0
    USBbuffer[7] = 0
    ProgramStart:
    USBSERVICE
    IF PORTD.0 = 0 THEN
    pause 5
    Goto DoUSBOut1
    goto ProgramStart
    DoUSBOut1:
    USBBufferCount = USBBufferSizeTX ' TX buffer size
    USBService ' keep connection alive
    USBOut 1, USBBuffer, USBBufferCount,DoUSBOut1 ' if bus available, transmit data
    Tipka3:
    USBService
    If PORTD.0 = 0 then
    pause 5
    goto tipka3
    USBbuffer[2] = $FF
    GOSUB DoUSBOut2
    GOTO programstart
    goto Tipka3
    DoUSBOut2:
    USBOut 1, USBBuffer, USBBufferCount,DoUSBOut2 ' if bus available, transmit data
    Merfy's Avatar
    Merfy Guest
    Default Usb Modifier keys
    Hey Faaktoo,
    What I think you are looking for are called modifier keys. The modifier keys are keys such as shift, ctrl, alt and so on. They are set by setting the value in USBbuffer[0].
    Modifier Key Bits
    0 LEFT CTRL
    1 LEFT SHIFT
    2 LEFT ALT
    3 LEFT GUI
    4 RIGHT CTRL
    5 RIGHT SHIFT
    6 RIGHT ALT
    7 RIGHT GUI
    For example,
    USBbuffer[0] = 00000010b
    would register as having the left shift button pressed. I haven't actually tested this, and it's been a while since I played with my pics so hopefully this helps you out.
    Mar 2008
    Gerogetown, Texas
    Here is a program I use to send key presses to the PC with various switches and encoders. You should be able to get the drift of what needs to happen to get caps, Ctrl, Alt etc.
    'Byte Description
    '0 Modifier keys
    '1 Reserved
    '2 Keycode 1
    '3 Keycode 2
    '4 Keycode 3
    '5 Keycode 4
    '6 Keycode 5
    '7 Keycode 6
    'Bit Key
    '0 LEFT CTRL    0x01
    '1 LEFT SHIFT   0x02
    '2 LEFT ALT     0x04
    '3 LEFT GUI
    '4 RIGHT CTRL   0x10
    '5 RIGHT SHIFT  0x20
    '6 RIGHT ALT    0x40
    '7 RIGHT GUI
    '               USB Key Code
    'Key    Mod     make           Action
    '                0x00           No Action
    ' 1     0        0x1E           5 NM
    ' 2     0        0x1F           10
    ' 3     0        0x20           20
    ' 4     0        0x21           40
    ' 5     0        0x22           80
    ' 6     0        0x23          160
    ' 7     0        0x24          320
    ' 8     0        0x25          640
    ' F2    0        0x3B          NAV
    ' F3    0        0x3C          AIRPORTS
    ' F4    0        0x3D          WAYPOINTS
    'CTRL-D 4        0x07           Toggle FLight Director
    ' G     0        0x0A           TO/GA Switch
    ' Q     0        0x14          Left NAV
    ' SHft-Q 2       0x14           ADF
    'CTRL-q  4       0z14           VOR1
    'CTRL-S  4       0x16           ND Center
        '   Interrupt definition
            '   USB interrupt used to keep USB connection alive
    INCLUDE "DT_INTS-18.bas"    ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ' Include if using PBP interrupts
    INT_LIST  macro    ; IntSource,         Label,  Type, ResetFlag?
            INT_Handler    USB_INT,  _DoUSBService,   ASM,  yes
            ;INT_Handler    RBC_INT,  _Selector,   PBP,  yes
            ;INT_Handler    INT1_INT,  _cent,   PBP,  yes
            ;INT_Handler    INT0_INT,  _CHK_Matrix,   PBP,  yes
    ' * main program loop - remember, you must keep the USB      *
    ' * connection alive with a call to USBService every couple  *
    ' * of milliseconds or so...                                 *
    UIE = $7F
    UEIE = $9F
    @   INT_ENABLE  USB_INT
    ;@   INT_ENABLE  RBC_INT
    ;@   INT_ENABLE   INT1_INT
    ;@   INT_ENABLE   INT2_INT
    gosub dousbin
    gosub dousbout
    sel_old = sel
    baro = PORTD & %00110000
    Baro_old = baro
    pta = porta
    pta_old = pta
    ptb_old = ptb
    na1 = portc & %11000000
    na1_old = na1
    na2 = portd & %00001100
    na2_old = na2
    'gosub selector
    'gosub barometric
    'gosub toggle1
    'gosub toggle2
    goto ProgramStart
    '  Jump to main program                                                     '
    '      Sub Routines
    ' * Send data to USB bus                            *
    Make:
    usbbuffer(0)= ModKey
    usbbuffer(1)= 0
    usbbuffer(2)= Key
    gosub Dousbout
    modkey = 0
    key = 0
    usbbuffer(0)= 0     'Clear buffer to stom multible key outputs
    usbbuffer(1)= 0
    usbbuffer(2)= 0
    gosub Dousbout
    ClrBuffer:         ' Clear usb buffer
    usbbuffer(0)= 0
    usbbuffer(1)= 0
    usbbuffer(2)= 0
    usbbuffer(3)= 0
    usbbuffer(4)= 0
    usbbuffer(5)= 0
    usbbuffer(6)= 0
    usbbuffer(7)= 0
    ' * receive data from the USB bus                            *
    DoUSBIn:
       USBBufferCount = USBBufferSizeRX              ' RX buffer size
       'USBService                                    ' keep connection alive
       USBIn 1, USBBuffer, USBBufferCount, DoUSBIn   ' read data, if available
    ' * wait for USB interface to attach                         *
    DoUSBOut:
       USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, transmit data
    Rot_Encoder:
         RotEncDir = New_Bits.3 ^ Old_Bits.2
         if RotEncDir = 1 then
              RotEnc1_val = RotEnc1_val + 1
              if RotEnc1_val > 8 then RotEnc1_val = 8
              RotEnc1_val = RotEnc1_val - 1
              if RotEnc1_val < 1 then RotEnc1_val = 1
    select case  RotEnc1_val         ' encoder counts from 1 to 8 and down from 8 to 1
        Case 1
        modkey = 0
        key = $1E
        Case 2
        modkey = 0
        key = $1F
        case 3
        modkey = 0
        key = $20
        case 4
        modkey = 0
        key = $21
        case 5
        modkey = 0
        key = $22
        case 6
        modkey = 0
        key = $23
        case 7
        modkey = 0
        key = $24
        case 8
        modkey = 0
        key = $25
    end select
    gosub make
    Old_Bits = New_Bits
       DoUSBService:    'Keeps USB alive
        usbservice
    @   INT_RETURN
    Selector:
    sel = portb & %11110000
    select case sel
    case $D0
    modkey = 0
    KEY = $10      'M   ND map mode
    case $B0
    modkey = 2
    KEY = $10      ' Shift M  ND VOR mode
    case $70
    modkey = 1
    KEY = $10      'CTRL M  ND APP mde
    end select
    gosub make
    sel_old = sel
    BaroMetric:
    if baro = $10 then
    modkey = 0
    KEY = $1A       ' W Toggle barimetric pressure to US in
    gosub make
    if baro = $20 then
    modkey = 0
    KEY = $19       ' V Toggle barimetric pressure to Euro
    gosub make
    baro_old = baro
    'Minimums:
    'if mins =  $40 then
    'endif
    'if mins = $80 then
    'endif
    'mins_old = mins
    'Return
    Push_Buttons:
            if porta.0 = 0 then  'Map NAV  F2
            modkey = 0
            KEY = $3B     'F2   Toggle mapstation display ND
            gosub make
            if porta.1 = 0 then 'Map APPT F3
            modkey = 0
            KEY = $3C     'F3   Toggle Airports ND
            gosub make
            if porta.2 = 0 then 'Map WPT F4
            modkey = 0
            KEY = $3D     'F4   Toggle waypoints ND
            gosub make
            if porta.3 = 0 then    ' MTRS
            modkey = 0
            KEY = $18   ' U Altitude metric mode
            if porta.4 = 0 then    ' Toggle FPV
            modkey = 1
            KEY = $5   ' CRTL B
            pta_old = pta
    Toggle1:
        if na1 = %11000000 then
            modkey = 0
            key = $14
            gosub make
        if na1 = %01000000 then
            modkey = 2
            key = $14
            gosub make
        if na1 = %10000000  then
            modkey = 1
            key = $14
            gosub make
    na1_old = Na1
    Toggle2:
        if na2 = %00001100 then
            modkey = 0
            key = $15
            gosub make
        if na2 = %00000100 then
            modkey = 2
            key = $15
            gosub make
        if na2 = %00001000  then
            modkey = 1
            key = $15
            gosub make
    na2_old = Na2
    '        End Sub Routines
    ProgramStart:
     if baro != baro_old then gosub barometric        ' Two position selector switch
    '' mins = PORTD & %11000000
    '' if mins != mins_old then gosub Minimums
    New_Bits = PORTB & %00001100   'check to see if any encoder has changes
    IF New_Bits != Old_Bits  then gosub rot_encoder    ' if changed process encoder
    ptb = portb.1               'Switch on Encoder circle
    if ptb != Ptb_old then
       If portb.1 = 0 then
        modkey = 1
        key = $16
        gosub make
      ptb_old = ptb
    sel = Portb & %11110000
    if sel_old != sel then gosub selector        ' 4 position selector switch
     pta = porta
     if pta != pta_old then  gosub Push_Buttons     'Push buttons
    if na1 != na1_old then  gosub Toggle1          'Toggle switches
    if na2 != na2_old then gosub Toggle2
    goto ProgramStart
    I had to take out a few lines so I did not exceed the post size limit
    Jan 2008
    Default Thank you !!!
    I'm resolved my problem and finished my project (with your help).
    Thank you, once again!!!
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 13:43
  2. Simple USB Comms Problem
    By awmt102 in forum mel PIC BASIC Pro
    Last Post: - 6th January 2010, 20:17
  3. AT/PS2 Keybord - PIC Interface?
    By Kamikaze47 in forum Code Examples
    Last Post: - 9th August 2009, 16:10
  4. One USB keyboard to Two USB Ports
    By picnaut in forum mel PIC BASIC Pro
    Last Post: - 11th June 2009, 00:04
  5. Working with indivividual bytes of an array
    By J_norrie in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2007, 19:16
