Compiler Errors
Results 1 to 4 of 4
Thread: Compiler Errors
    Conspiracy Bro's Avatar
    Conspiracy Bro Guest
    Default Compiler Errors
    I do not know what the problem is but i can't get rid of these compiler errors, would anyone have any idea? I am a beginner with programming PIC's. The errors are listed below following the code that the compiler does not like. Any help here would be greatly appreciated. I am using a PIC16F628
    Message[302] C:\KEYPAD.ASM 36 : Register in operand not in bank 0. Ensure that bank bits are correct.
    Message[302] C:\KEYPAD.ASM 38 : Register in operand not in bank 0. Ensure that bank bits are correct.
    BSF STATUS,5
    MOVLW b'11111000'
    MOVWF TRISA
    MOVLW b'11100000'
    MOVWF TRISB
    Warning[205] C:\KEYPAD.ASM 290 : Found directive in column 1. (end)
    Error[173] C:\KEYPAD.ASM 291 : source file path exceeds 62 characters (C:\KEYPAD.ASM)
    Error[173] C:\KEYPAD.ASM 291 : source file path exceeds 62 characters (C:\P16F628A.INC)
    just a simple question here. wich software do you use to compile assembler ? MPLAB?
    In case you use PicBasic your assembly language lines will not work insead you do not declare these lines as assembly section.
    bsf PORTA.0
    regards
    New England
    Hi Conspiracy Bro,
    On the"message 302"s - I think that's because TRISA and TRISB are both in memory bank 1.
    The ASM command sets the bank to zero, so you'll have to set the bank back to 1 in your ASM section before modifying the TRIS registers.
    Make sure to re-set the bank as needed before leaving the ASM section.
    <<<EDIT>>>> Duhh - I now see you did that already...
    After a few try, i appear that you'll always get error when dressing to TRIS. there's another method and it will gives you also an error message
    like this:
    MOVLW b'11111000'
    TRIS PORTA
    MOVLW b'11100000'
    TRIS PORTB
    They will say that is not recomended...bla bla...
    In your case
    list p=16f628
    include "p16f628.inc"
    org 000H
    goto start
    ORG 005H
    start CLRF PORTB
          CLRF PORTA
          BSF STATUS,RP0 ;SWITCH TO BANK1
          MOVLW b'11111000'
          MOVWF TRISA
          MOVLW b'11100000'
          MOVWF TRISB
          BCF STATUS,RP0 ;RETURN TO BANK0
          ;place you code there
    this is working but with error message bullsh... on BANK0 that we set correctly... as i expect.
    regards
  1. Compilation errors - strange
    By tetanus4 in forum mel PIC BASIC Pro
    Last Post: - 24th October 2009, 20:04
  2. Replies: 3
    Last Post: - 1st July 2008, 22:07
  3. compiler help!!!!
    By MINHLE in forum mel PIC BASIC Pro
    Last Post: - 20th April 2008, 19:52
  4. Picbasic Pro Demo assembly errors
    By mikeRho in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2008, 07:41
  5. Microcode Studio Plus compile/assmebly errors
    By mikehagans in forum mel PIC BASIC Pro
    Last Post: - 18th February 2006, 22:31
