+ Reply to Thread
Results 1 to 16 of 16
Thread: Vinculum Vdrive2
    Lancashire
    Default Vinculum Vdrive2
    Hi All
    I`m assuming its probably the right place to put this since its USB related. Has anyone done any work with the Vdrive2 module from FDI?.
    Cheers Pete
    Oct 2006
    Default VDIP1 may be close
    It looks to me that FDTI make several related products from the one hardware and code set.
    I placed some sample code for the VDIP1 in the "Code Examples" section of this site some months ago that might help.
    HTH
    Brian
    Lancashire
    Hi Brian
    Thanks, I`ve got a copy of this now. There is an error on the Vdrive2 sheet I have also found. The link for SPI/UART is incorrect on both the overlay and the example with a micro. The 0v and 3V3 are transposed, in the example for microcontroller the link is in the position for SPI and not UART mode which is being used.
    Cheers Pete
    Nov 2008
    Default Vdrive2 logger
    I have built a logger using the Vdrive2 and wrote a blog on it. At the blog I posted schematics and code for both a 8 bit and 10 bit version. The logger uses a DS1307 for a time stamp and saves data at 1 per second using a 16F688 pic and Pic Pro Basic.
    Omaha, Nebraska USA
    The VMusic2 is also cute.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Nov 2007
    South-West of Australia. A small town called Denmark. 'Where the forest meets the sea.'
    Default Vdrive2
    For Bill/mark Sherman at BOTSMAKER
    Thanks for taking the trouble to put your VDRIVE2 project on the web.
    I'm just starting with my VDRIVE2 and have been trawling through your PIC Basic Pro code to learn how to do it.
    I'm not clear why your 'write' command works? According to the FTDI notes the command is:
    "WRF", $hhhh
    Where $hhhh is a word that is the number of BYTES following that are to be written to the currently open file.
    Your format seems to be:
    "WRF",$00,$00,$00,$15,$0d,DEC yy10.........
    Why does this work please?
    Regards Bill Legge
    Nov 2008
    Default Vinculum Write Command
    Whats wrong with it? $00 $00 $00 $15 = 21 in decimal. This tells the vinculum that 21 bytes will follow to be written. If you add up the bytes, you get 21.
    Nov 2007
    Default VDrive2
    Thanks for your reply.
    I thought the VDrive2 would take the first four hex numbers after the "WRF" and read zero bytes to follow?
    What are the $00 doing?
    Regards Bill legge
    Nov 2008
    Default WRF command
    WRF is reading a long word of 32 bits, starting with MSB first. So if the first 3 bytes are zero, you must read in a zero. You can't take a short cut and just send $15.
    Nov 2007
    Default Vdrive2
    I'd not seen that the VDrive2 was looking for a LONG.
    Regards Bill Legge
    This also works
    SEROUT2 VRXD, 188,["WRF 24",13]
    The above prepares the VDIP for 24 characters. The next command would be something like this
    SEROUT2 VRXD, 188,["X",DEC2 HH,DEC2 MM,DEC2 SS,_
        DEC2 ND,DEC2 NM,DEC3 NMD,DEC3 WD,DEC2 WM,DEC3 WMD,13,10]
    And the VDIP is not looking for a LONG as in PBP LONG. The VDIP just needs to know how many characters it is expected to write.
    http://mackrackit.cambs.net/
    Nov 2008
    Default WRF command
    Thank you, thats good to know, I'm making too much work out of it.
    Quote Originally Posted by botsmaker View Post
    Thank BrianT. I got started with the VDIP using his code that is posted in the code example section.
    The data sheet is very poor or misleading. I would not have gotten very far with the data sheet alone.
    Mar 2010
    Default how to read back return value from command DSN
    DSN is to monitor disk serial number
    can i know how the return value can be readen from 16f688 and doing a comparison ?
    i am using c language writing the software
    is they any sample i can refer?
    May 2012
    Default Re: Vinculum Vdrive2
    WE are using VDRIVE2 with Firmware Ver 03.66VDAPF.We are interfacing it with our USB device which is a fingerprint sensor Morphosmart MSO CBM.Details of the Slave Device (fingerprint sensor):
    - Communication Class Device in accordance with USB Device Class Specifications version 2.0
    - The Device use full speed transfer rate of 12Mbits/s
    - Compatible with USB 1.1 and USB 2.0 hosts and hubs
    WE tested our sensor with a GET DESCRIPTOR string using the command mode. We are getting desired response when we send the 'DRD' command. But, on our application we don't want the command interface. We want to send/receive data transparently (i.e. w/o using any commands).
    The GET DESCRIPTOR string is a data that we send to the sensor , after which the sensor replies:
    SYNCïÿìName: CBM
    Mobi5 Serial Number: 0944
    This is our GET DESCRIPTOR string (18 Bytes):
    $53$59$4E$43$04$00$00$00$FB$FF$FF$FF$05$01$00$2F$4 5$4E
    In the above string $53 is a hex value, so we are sending 18 bytes written above in HEX format. We send these values using a Windows XP PC serial PORT. On the PC we are using Terminal v1.9b software (Bray++) and we send hex data using the transmit macros field in Terminal software.
    Now while testing, we used the device in command mode initially. Selected the device SC 1 and then pulled the DATAREQ line (pin 36 of VNC1L) low (0V), after that the DATAACK line also became low. So now vdrive2 is in DATA MODE. But, now if we send the GET DESCRIPTOR string then we DON'T get the desired response. Rather we don't get any response from the device. Thus, we fail to interface the sensor in data mode.
    But the same can be done successfully using command mode only and the following is the device log:
    Command mode successful trial log:
    Commands:
    ipa
    qp2
    qd 0
    qd 1
    sc 1
    dsd 18
    %%%%%%%% Comment: send the GET DESCRIPTOR string (18 Bytes) using the transmit macros field in Terminal software. %%%%%%%%%%%%
    drd
    Responses:
    D:\>
    $10 $00
    D:\>
    $01 $20 $81 $10 $00 $00 $00 $10 $01 $02 $00 $02 $02 $01 $9B $07 $47 $00 $00 $01 $01 $00 $00 $00 $00 $00 $00 $00 $00 $00 $00 $00
    D:\>
    $01 $20 $83 $40 $02 $40 $03 $00 $01 $02 $01 $0A $00 $00 $9B $07 $47 $00 $00 $01 $01 $00 $00 $00 $00 $00 $00 $00 $00 $00 $00 $00
    D:\>
    $40
    SYNCïÿìName: CBM
    Mobi5 Serial Number: 0944D:\>
    Our objective is to interface without using any commands after we select the device (i.e. after sc 1). We want to send our data (for eg. the GET DESCRIPTOR string ) directly to the sensor and get the response from the sensor without using any commands. P.S.:We have also tried the VCDC firmware and failed in a similar manner i.e. we didn't get any reply from the sensor.
    Nov 2008
    I got inconsistent responses with different usb flash drives so I gave up using the Vinculum for use as a data logger. I will be looking into using a SD card or a Datakey from Datakey Electronics. http://www.datakeyelectronics.com/ With the Datakey, the interface is made to go with the key. With USB sticks, you don't know what your getting.
    Hi, we are pleased to see that you are using our forum.
    We'd like you to become a member of our community. Membership is FREE, please REGISTER and view our forums without these annoying reminders!
    Once registered you may post on the forums, download from the file areas and use the WIKI without interruption.
+ Reply to Thread
  1. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 4th April 2012, 06:43
  2. Vinculum and CP2102
    By WEspezial in forum Forum Requests
    Last Post: - 22nd June 2009, 08:00
  3. Vinculum VNC1L Vdrive2 module problems
    By the_virus in forum Serial
    Last Post: - 21st July 2008, 07:01
  4. help me to read data from vdrive2
    By prameela in forum General
    Last Post: - 19th March 2008, 09:20
  5. VDIP1 (Vinculum - FTDI) problems
    Last Post: - 11th December 2007, 23:47
Members who have read this thread : 10
