Scale 8bit ADC RGB LED voltmeter
Results 1 to 2 of 2
    Sep 2006
    Indiana, USA
    Default Scale 8bit ADC RGB LED voltmeter
    I borrowed some code from a EDN.com article for what they call a "rainbow voltmeter" programmed in PBP.. the article takes a 12F675 and uses a RGB led to display a different color based on an 8 bit ADC input, shifting from "aqua" to "white" based on a voltage from 0 to 5 volts. at 2.5 volts the circuit switches the LED off for center dark. I modified the code a bit to get rid of the dark part, as i thought it was un-needed. I would like however, to scale the software to the lowest color "aqua" to = 1.60V and the highest color "white" = to 2.25V. I cant access the VREF pin (not because its in use by the LED, but because the circuit is already built)and "biasing" my input is a no go as well. It will have to be a mod of the software. they say that it is possible to do so in the article, but don't really say how and my math is terrible, like learning disability terrible! so if someone could show me some code, or the math, thank you! anyway, the following is the orignal code as printed by EDN.com
    ' PicBasic Pro program to read A/D on 12F675 ADC
    ' and display voltage A/D output using multi-color LED
    ' using a cold-to-hot color pallette. Center of range
    ' is dark.
    ' (c) 2003 by David Prutchi
    i VAR BYTE ' Define loop variable
    blue VAR BYTE ' Define blue pulse-width variable
    green VAR BYTE ' Define green pulse-width variable
    red VAR BYTE ' Define red pulse-width variable
    ' GPIO port 0 to GREEN LED
    ' GPIO port 1 TO RED LED
    ' GPIO port 2 to BLUE LED
    color VAR BYTE ' Define LED color variable
    x VAR BYTE ' Allocate A/D variable
    ' Set A/D Parameters
    DEFINE ADC_BITS 8 ' Use 10-bit A/D as 8-bit A/D
    ANSEL.3=1 ' Set ANS3 as analog input pin
    ANSEL.4 = 0 ' Set A/D clock
    ANSEL.5 = 1
    ANSEL.6 = 0
    ADCON0.0 = 1 ' Turn On A/D
    ADCON0.2 = 1 ' A/D channel 3
    ADCON0.3 = 1
    ADCON0.6 = 0 ' VDD is voltage reference
    ADCON0.7 = 0 ' Left Justify result
    ' Set GPIO port pins 0, 1 and 2 as outputs
    TRISIO.0=0
    TRISIO.1=0
    TRISIO.2=0
    GoTo mainloop ' Skip subroutines
    ' SUBROUTINES
    ' Subroutine to read a/d converter
    getad:
    ADCON0.1 = 1 ' Start conversion
    PauseUs 50 ' Wait for conversion
    x = ADRESH
    ' MAIN
    mainloop:
    GoSub getad ' Get x value by performing A/D conversion
    ' RGB ENCODING FUNCTION
    ' Convert A/D reading into color table
    ' Each color has 14 possible intensity levels
    IF x<=42 Then 'aqua
    red=x/3
    blue=14
    green=(42-x)/3
    EndIF
    IF x>42 AND x<=84 Then 'shades of violet
    red=(84-x)/3
    green=0
    blue=14
    EndIF
    IF x>84 AND x<=126 Then 'shades of green
    red=0
    green=0
    blue=(126-x)/3
    EndIF
    IF x>126 AND x<=130 Then 'dark
    red=0
    green=0
    blue =0
    EndIF
    IF x>130 AND x<=172 Then 'shades of red
    red=(x-130)/3
    green=0
    blue=0
    EndIF
    IF x>172 AND x<=214 Then 'red / orange / yellow
    red=14
    green=(x-172)/3
    blue=0
    EndIF
    IF x>214 Then 'yellow to white
    red=14
    green=14
    blue=(x-214)/3
    EndIF
    ' PULSE WIDTH MODULATOR
    ' Each PWM frame has 14 steps.
    For i = 1 TO 14 ' Cycle through 14 steps of frame
    color=0
    IF red>0 Then
    color=color+2
    red=red-1
    EndIF
    IF green>0 Then
    color=color+1
    green=green-1
    EndIF
    IF blue>0 Then
    color=color+4
    blue=blue-1
    EndIF
    GPIO=color
    PauseUs 100 ' Allow LEDs to shine for a few microseconds
    Next i
    GPIO=0
    GoTo mainloop ' Do it forever
    skimask's Avatar
    skimask Guest
    disable
    blue var byte:green var byte:red var byte:greenled var gpio.0
    redled var gpio.1:ansel=$68:greenled var gpio.0:trisio=0:temp var word
    pwmcount var byte:adread var word:adcon=$8d:goto mainloop
    on interrupt goto inthandle
    inthandle:
    if intcon.2 = 1 then   'tmr 0 overflow fired off
         intcon.2 = 0 : pwmcount = pwmcount + 1 : if pwmcount = 0 then gpio = 0
         if green > pwmcount then greenled = 1
         if blue > pwmcount then blue = 1
         if red > pwmcount then red = 1
    if pir1.6 = 1 then      'a/d convert int fired off
    pir1.6=0:adread.highbyte=adresh:adread.lowbyte=adres
    if adread < 327 then adread = 0  'if less than minimum zero it
    if adread > 460 then adread = 133  'if more than max, max it out
    adread = adread - 327  'range of 133 (.0048828125 volts/bit)
    adread = adread * 30   'scale it up to reach 12 usable bits
    red=0:red.7=adread.11:red.6=adread.10:red.5=adread.9:red.4=adread.8
    blue=0:blue.7=adread.7:blue.6=adread.6:blue.5=adread.5:blue.4=adread.4
    green=0:green.7=adread.3:green.6=adread.2:green.5=adread.1:green.4=adread.0
    resume
    enable
    mainloop:     @ nop
    if adcon.1 = 0 then adcon.1 = 1
    @ nop
    goto waitforad
    Try that for grins...
    The LEDs should follow the voltage from 0 to 5v. If it actually works (I haven't tried it), you should be able to scale adread when it's read according to what you want to do. I just threw this together. Anything less than 1.6v, LEDs are dark, more than 2.25v LEDs are full bright, anything in between, the number gets converted to a 12bit value, high 4 bits to red, mid 4 bits to green, low 4 bits to blue.
    Last edited by skimask; - 22nd February 2008 at 03:49. Reason: Changed it up a bit
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 04:59
  3. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 20:19
  4. RGB LED Matrix
    By ERIK in forum mel PIC BASIC Pro
    Last Post: - 28th June 2008, 07:01
  5. LCD will not start
