Need help with config
Results 1 to 19 of 19
    Mar 2004
    Default Need help with config
    I am trying to set up internal asc and MCLr options in the config of my code for a 16f688. The data sheet has the config bits for all of this on page 100. Is there an easy way of setting this? I tried config=%11001111000100 nut this did not work. I got a syntax error. The posts that I have read seem to set each function in the config individualy. Can some one point me in the right direction.
    Feb 2005
    Essex, UK
    I may have mis-understood your post but if you're just trying to set the configuration bits try:
    for PM Assembler:
    @ device INT_OSC, MCLR_OFF
    Is this what you're after?
    Kind regards
    Rob
    Hi Darrenmac,
    see this thread for configs.
    Feb 2005
    Essex, UK
    Hi Darrenmac,
    Yeah, that's a good thread - should've posted a link to it myself!
    Mar 2004
    I have read the suggested post again. All examples in this post appear to set each option in the config seperatly, ie pic type, mclr, pwrt as seperate comands but the datasheet for the 16f688 shows a config register called 11.1 (page 100) with each option as seperate bits either set or cleared. Can I just send this as a binary string (or hex equivelent)? if so how?
    Quote Originally Posted by Darrenmac View Post
    It never worked that way for me, every newbie reads that and tries it,(I did) and it has never worked that I heard of. You can string the commands together though, like so:
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON & _LVP_OFF & _CP_ALL & _DATA_CP_ON
    The data sheet shows you what happens in those registers, but you can access them only at program time and require you to use the proper syntax as shown in Melanies post.
    Mar 2004
    Ok that clears that up a bit. I guess its more reading and experementing. Thanks
    Mar 2004
    I have tried some of the examples in the suggested post but I get compile errors.
    Here are some of what I have tried
    @ CONFIG FOSC = HS
    opcode expected instead of config
    CONFIG OSCS=OFF ; Oscillator switch OFF
    Same error
    @ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HS_OSC_1H
    Same error
    I am using Picbasicpro with microcode studios
    Looks like you're still stuck...
    I need some information... are you using Microchip's MPASM or MeLab's PM as the Assembler? or don't you know?
    If you don't know, then I'll have to install MicroCode Studio which I don't ever use and see what the default's are when trying to compile for this chip.
    Oh, finally, what version of PBP are you running?
    Mar 2004
    I thought that MElabs PBP was the compiler. I have ver 2.5.
    Wink R.t.f. Datasheet !!!
    IF you use MPASM as assembler,
    The Config. fuses ***NAMES*** FOR THE '688 are:
    ( do not care of the EQU H" xxxx" )
    ;       Configuration Bits
    _FCMEN_ON                    EQU     H'3FFF'
    _FCMEN_OFF                   EQU     H'37FF'
    _IESO_ON                     EQU     H'3FFF'
    _IESO_OFF                    EQU     H'3BFF'
    _BOD_ON                      EQU     H'3FFF'
    _BOD_NSLEEP                  EQU     H'3EFF'
    _BOD_SBODEN                  EQU     H'3DFF'
    _BOD_OFF                     EQU     H'3CFF'
    _CPD_ON                      EQU     H'3F7F'
    _CPD_OFF                     EQU     H'3FFF'
    _CP_ON                       EQU     H'3FBF'
    _CP_OFF                      EQU     H'3FFF'
    _MCLRE_ON                    EQU     H'3FFF'
    _MCLRE_OFF                   EQU     H'3FDF'
    _PWRTE_OFF                   EQU     H'3FFF'
    _PWRTE_ON                    EQU     H'3FEF'
    _WDT_ON                      EQU     H'3FFF'
    _WDT_OFF                     EQU     H'3FF7'
    _LP_OSC                      EQU     H'3FF8'
    _XT_OSC                      EQU     H'3FF9'
    _HS_OSC                      EQU     H'3FFA'
    _EC_OSC                      EQU     H'3FFB'
    _INTRC_OSC_NOCLKOUT          EQU     H'3FFC'
    _INTRC_OSC_CLKOUT            EQU     H'3FFD'
    _EXTRC_OSC_NOCLKOUT          EQU     H'3FFE'
    _EXTRC_OSC_CLKOUT            EQU     H'3FFF'
    _INTOSCIO                    EQU     H'3FFC'
    _INTOSC                      EQU     H'3FFD'
    _EXTRCIO                     EQU     H'3FFE'
    _EXTRC                       EQU     H'3FFF'
    IF Using PM assembler they are :
    					; *** DEVICE Fuses Definitions
    EXTRC		equ	3FF80007h       ; XX XXXX XXXX X111
    EXTRC_OSC_CLKOUT equ    3FF80007h       ; XX XXXX XXXX X111
    EXTRCIO		equ	3FF80006h       ; XX XXXX XXXX X110
    EXTRC_OSC_NOCLKOUT equ  3FF80006h       ; XX XXXX XXXX X110
    EXTRC_OSC       equ     3FF80006h       ; XX XXXX XXXX X110
    INTOSC		equ	3FF80005h       ; XX XXXX XXXX X101
    INTRC_OSC_CLKOUT equ    3FF80005h       ; XX XXXX XXXX X101
    INTOSCIO	equ	3FF80004h       ; XX XXXX XXXX X100
    INTRC_OSC_NOCLKOUT equ  3FF80004h       ; XX XXXX XXXX X100
    INTRC_OSC       equ     3FF80004h       ; XX XXXX XXXX X100
    EC_OSC          equ     3FF80003h       ; XX XXXX XXXX X011
    HS_OSC          equ     3FF80002h       ; XX XXXX XXXX X010
    XT_OSC          equ     3FF80001h       ; XX XXXX XXXX X001
    LP_OSC          equ     3FF80000h       ; XX XXXX XXXX X000
    WDT_ON          equ     3FF70008h       ; XX XXXX XXXX 1XXX
    WDT_OFF         equ     3FF70000h       ; XX XXXX XXXX 0XXX
    PWRT_OFF        equ     3FEF0010h       ; XX XXXX XXX1 XXXX
    PWRT_ON         equ     3FEF0000h       ; XX XXXX XXX0 XXXX
    MCLR_ON         equ     3FDF0020h       ; XX XXXX XX1X XXXX
    MCLR_OFF        equ     3FDF0000h       ; XX XXXX XX0X XXXX
    PROTECT_ON      equ     3FBF0000h       ; XX XXXX X0XX XXXX
    PROTECT_OFF     equ     3FBF0040h       ; XX XXXX X1XX XXXX
    CPD_ON          equ     3F7F0000h       ; XX XXXX 0XXX XXXX
    CPD_OFF         equ     3F7F0080h       ; XX XXXX 1XXX XXXX
    BOD_ON          equ     3CFF0300h       ; XX XX11 XXXX XXXX
    BOD_NSLEEP      equ     3CFF0200h       ; XX XX10 XXXX XXXX
    BOD_SBODEN      equ     3CFF0100h       ; XX XX01 XXXX XXXX
    BOD_OFF         equ     3CFF0000h       ; XX XX00 XXXX XXXX
    IESO_ON         equ     3BFF0400h       ; XX X1XX XXXX XXXX
    IESO_OFF        equ     3BFF0000h       ; XX X0XX XXXX XXXX
    FCMEN_ON        equ     37FF0800h       ; XX 1XXX XXXX XXXX
    FCMEN_OFF       equ     37FF0000h       ; XX 0XXX XXXX XXXX
    These sets of fuse NAMES are particular to the Pic you use ...
    SO ...
    THIS
    doesn't mean ANYTHING with a 16F688 ...
    Capito ???
    Mar 2004
    Does this need to be in assembler or in straight basic
    Default Use Mpasm
    Hi Darrenmac,
    Microcode Studio defaults to using the PM assembler, to use MPASM you have to tell it to, here is how: 1.start micro code studio 2. click on the word VIEW at the very top left. 3. Click on Compile and Program Options, and it will open a box which has at it's top, 3 tabs, notice on the first tab an empty box which says use PBL, but do not put a check there, click the center tab marked assembler. You will see an empty box marked: USE MPASM. Put a check mark there and close the box. You are now using MPASM as the assembler.
    JS
    Mar 2004
    So do I use
    @ MCLR_OFF
    or
    MCLR_OFF
    Feb 2005
    Essex, UK
    So do I use
    @ MCLR_OFF
    or
    MCLR_OFF
    Hi Darrenmac,
    If you have not changed your settings as per Joe S's last post then you are using the PM assembler as this is what Microcode Studio defaults to. In this case see Post#2 in this thread.
    If you have changed your settings as per Joe's last post then you need to use:
    @ __CONFIG _INTOSC & _MCLRE_OFF
    Cheers
    Rob
    Hi Darrenmac,
    Now after you do all this you will get a compile error telling you you are overwriting the configs . . . that's because you are. In your PBP directory you will have many files with the suffix .inc and the filename will be the number of your PIC. Open it and you will see the following code:
    __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
    just put a semi colon at the beginning like this:
    ;__config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
    save the file and then no more error. This config is the " DEFAULT" config setting in case you forget to put in any config so your program will still work sometimes.<br>
    Now, why go through all of this? Well suppose you DO NOT want to use the internal oscillator? The DEFAULT configs will not work with a crystal or resonator or EXT oscillator, so do it now and get used to setting the fuses early into your adventure into PIC Magic
    Mar 2004
    Still having issues, I think that I am going to be better off by setting them in the programmer. At least I can get it to work. Thanks for every one who has tried to help
    Setting them in the programmer works. but if you ever want to just program a chip from a saved hex file, your going to get bit in the behind if you don't remember what settings you used in the programmer. its really a two step operation. PBP is the basic compiler, it creates an assembler file. then either pm or msasm compiler assembles that into your hex file that gets programmed into the chip. the fuse names/settings are written into your basic program but are dependant upon which assembler you use. The assembler is what uses these config commands. PBP passes these to the assembler with the @. so your line would be either
     @_config MCLR OFF
    or
     @_config MCLRE OFF
    depending on if pm or msasm is used.
    Default oops
    thats actually
     @_config _MCLR_OFF
    or
     @_config MCLRE_OFF
    the hs osc you were trying should be
    @_config _HS_OSC
    or
    @_config HS_OSC
    someone please check my writing, i can't see the _'s during preview on here. (not at home and using my phone lol)
  1. Run-Time Config
    By Darrel Taylor in forum PBP Extensions
    Last Post: - 1st February 2012, 16:26
  2. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 01:48
  3. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 23:51
  4. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 17:20
  5. Installation sequence
    By Demon in forum General
    Last Post: - 11th July 2006, 03:56
