Who can help me checking my Programming
THE BOOK of DT's INTERRUPTS is an organization of interrupt service routines and other works written by Darrel Taylor, RIP.
Interrupt routines are arranged per Darrel's original list. Darrel Taylor's Instant Interrupts are an extension of the work of Tim Box whom in October of 2002 wrote INT_CTRL.pbp
Many of the forum members felt this is a long overdue project.
will be a valuable resource and a tribute to Darrel Taylor the "Fanatical Contributor".
THE BOOK of DT's INTERRUPTS is located at http://dt.picbasic.co.uk/
+ Reply to Thread
Results 1 to 26 of 26
    Jan 2008
    Default Who can help me checking my Programming
    'My programming running is like that.....i want my programming every 5second send out the data to bluetooth module and using the bluetooth transmitter to Receiver on PC bluetooth and also show the value on LCD.....so below is my programming i dunno correct or not hope same one can help me checking it and let me knw where i wrong it urgent...!
    '* Name : WIRELESS TEMP MONITORING SYSTEM.BAS *
    '* Notice : Copyright (c) 2008 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 1/9/2008 *
    '* Version : 1.0 *
    '* Notes : *
    include"modedefs.bas"
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 50
    DEFINE debug_mode 1
    DEFINE debug_reg portc
    DEFINE debug_bit 6
    DEFINE debug_baud 2400
    pause 2000
    LCDOUT 254,1,2,2,2,"WELCOME MY"
    LCDOUT 254,192,2,"MONITOR SYSTEM"
    pause 3000
    LCDOUT 254,1,16,2,"MY STARTING"
    LCDOUT 254,192,2,"TEMP IS: "
    TRISA=255
    TRISC.6=0
    TRISD=0
    TRISA.0=1
    B0 VAR BYTE
    baud con N2400
    MAIN:
    ADCON1=3
    ADCIN 0,B0
    if b0=0 then OUTT
    IF B0=10 THEN OUT
    IF B0=20 THEN OUT1
    IF B0=30 THEN OUT2
    IF B0=41 THEN OUT3
    IF B0=51 THEN OUT4
    IF B0=61 THEN OUT5
    IF B0=71 THEN OUT6
    IF B0=81 THEN OUT7
    IF B0=92 THEN OUT8
    IF B0=102 THEN OUT9
    IF B0=112 THEN OUT10
    IF B0=122 THEN OUT11
    GOTO MAIN
    OUTT:
    LCDOUT 254,201,2,"<0'C"
    SEROUT PORTC.6,baud, [#B0=0]
    GOTO MAIN
    OUT:
    LCDOUT 254,201,2,"10'C "
    SEROUT PORTC.6,BAUD, [#B0=10]
    GOTO MAIN
    OUT1:
    LCDOUT 254,201,2,"20'C "
    SEROUT PORTC.6,BAUD, [#B0=20]
    GOTO MAIN
    OUT2:
    LCDOUT 254,201,2,"30'C "
    SEROUT PORTC.6,BAUD, [#B0=30]
    GOTO MAIN
    OUT3:
    LCDOUT 254,201,2,"40'C "
    SEROUT PORTC.6,BAUD, [#b0=41]
    GOTO MAIN
    OUT4:
    LCDOUT 254,201,2,"50'C "
    SEROUT PORTC.6,BAUD, [#b0=51]
    PAUSE 1000
    GOTO MAIN
    OUT5:
    LCDOUT 254,201,2,"60'C "
    SEROUT PORTC.6,BAUD, [#b0=61]
    GOTO MAIN
    OUT6:
    LCDOUT 254,201,2,"70'C "
    SEROUT PORTC.6,BAUD, [#b0=71]
    GOTO MAIN
    OUT7:
    LCDOUT 254,201,2,"80'C "
    SEROUT PORTC.6,BAUD, [#b0=81]
    GOTO MAIN
    OUT8:
    LCDOUT 254,201,2,"90'C "
    SEROUT PORTC.6,BAUD, [#b0=92]
    GOTO MAIN
    OUT9:
    LCDOUT 254,201,2,"100'C "
    SEROUT PORTC.6,BAUD, [#b0=102]
    GOTO MAIN
    OUT10:
    LCDOUT 254,201,"110'C "
    SEROUT PORTC.6,BAUD, [#b0=112]
    GOTO MAIN
    OUT11:
    LCDOUT 254,201,"120'C "
    SEROUT PORTC.6,BAUD, [#b0=122]
    GOTO MAIN
    skimask's Avatar
    skimask Guest
    baud con N2400
    Won't work... A constant is a numeric value. N2400 may have a numeric value associated with it, but N2400 itself is not a numeric value.
    You've got DEBUG defined as PortC.6, and SEROUT going to the same place.
    Which one is it?
    #B0=0? What's that for? The manual doesn't have anything like that in it...
    How about some of this:
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 3
    trisa = $ff : trisc = 0 : b0 var byte : pause 2000
    LCDOUT 254 , 1 , "   WELCOME MY   " , 254 , 192 , 2 , " MONITOR SYSTEM "
    pause 3000 : LCDOUT 254 , 1 , "  MY STARTING   " , 254 , 192 , "TEMP IS: "
    TRISA = 255 : TRISC.6 = 0 : TRISD = 0 : TRISA.0 = 1 : B0 VAR BYTE
    MAIN:    ADCON1 = 3 : ADCIN 0 , B0 : lcdout 254, 201, "<"
    if b0 = 0 then lcdout 254, 201, " "
    lcdout 254, 202, DEC ( b0 ) , "'C" : serout portc.6, n2400, #b0
    pause 5000 : goto main
    Lots of colons, shorter, easier to read in my mind...yes...Your job to figure out what's different. It's all in the manual.
    But the main thing is...
    We've got no idea which PIC you're using, which version of PBP, no idea what the problem is that you are having (although I can guess by looking at your code), no idea what your circuit actually looks like...
    Jan 2008
    hello i using PIC 16F877A and the B0 is the ADC after convert and i also using the temperature sensor to detect the temperature and every 5s i want the lcd show out my result at the same time i also need to send out the result to host bluetooth on pc at there also will show out the same result....so what should i do it............!i hope u all can help me....urgent..........!!! thanks a lot ..........!!!!
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by slimpeng View Post
    Did you see Post #2?
    Do you want the program written FOR you, hardware built FOR you, hand delivered TO you? Tomorrow?
    The program in Post #2 is practically written FOR YOUR PARTICULAR APPLICATION! HELLO!!! Anybody Home!!! McFLY!!!
    That is of course IF your hardware is set up right. And another thing, we'd need to know what kind of temperature sensor you're using...
    Is it a DS1820 type thing?
    A Alumel/Chromel thermocouple pair connected to an op-amp?
    A handheld infrared laser detector with an analog output?
    An ape slapping a stick on the ground with a candle at his feet, the hotter his feet, the harder he slaps the ground, the ground is a pressure sensitive resistor tied to a voltage divider network?)
    Heck, I even put a 5 second delay in there.
    Do you want the PC code and Bluetooth interface code written too?
    If it's that urgent, why didn't you get it done earlier?
    'school project' gone bad?
    Maybe you can pay somebody to do it for you...oh...wait...I think I already did. Where's my money?
    I'm out...
    Hi slimpeng,
    to start off with, replace baud con N2400, with baud con 4 , that will give you mode 4 which is N2400. You have several sub directories which output set temps, which the IF then loop will only address if the B0 variable exactly matches the number. what if the number is 11 or 19? the loop misses and goes around again, unless you do an AND less than type statement, I am curious as to why not lose all those subdirectories and output the actual B0 variable if it holds the accurate temp.something like:
    loop:
     LCDOUT 254,201,"The Temp is"#B0 'or
     SEROUT PORTC.6,BAUD, ["The Temp is",#B0]
    HTH
    JS
    Italy
    Frustration-Aggression Theory:
    Frustration is a feeling of tension that occurs when our
    efforts to reach some goal are blocked. When this occurs,
    it can produce feelings of anger, which in turn can generate
    feelings of aggression and aggressive behavior. This theory
    has been utilized to explain a lot of violent behavior over
    time. For example, some have stated that people who become
    frustrated with their jobs because they don't like their work,
    can't get the raise they want, etc., but can't take out their
    aggressions at work (can't yell at the boss, can't punch
    annoying co-workers), will redirect this frustration and act
    aggressively toward others.
    Jeremy,
    If you don't have any patience, do not participate in this forum!
    Best regards,
    Luciano
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by Luciano View Post
    Jeremy,
    Best regards,
    Luciano
    Holy crap...
    I've got loads of patience, LOADS I tell ya, hours and hours of it, sitting around waiting to be used...
    But, again, holy crap, when the answer, or at least a fairly decent chunk of an answer is sitting right there...RIGHT THERE in front of a person...I mean, jeez, how much more prompting does a person need to get off their rear end and try to figure something out.
    Jan 2008
    Now i attach my circuit diagram...for u all see so the progrmming can running this circuit or not....
    skimask's Avatar
    skimask Guest
    'bout time.
    Check your other thread...
    Nov 2007
    West Covina, CA
    Thumbs down Dude! Take a chill pill! Better yet a sabbatical...
    Holy crap...
    I'm probably not the only one that hesitates asking a simple question for fear of getting a verbal lashing for reading and not understanding the information provided either in responses or the data sheets. Or having to have our project pre-approved by you before making a suggestion. In my searches to my questions through out this forum, to keep from "bothering the experts", I found that one thing is evident, it's not the year 2004 when there seemed to be an eagerness to "help" upcoming PBP users. Your definition of patience is warped and unfortunately it seems to me that some of the other "experts" are getting tired too.
    If you feel your forehead forming a scowl as you read someones annoying and dumb question, do us a favor... don't respond. Because a lot of us are not at the same experience level you are and don't need the added aggrevation that comes with learning something new.
    My two cents.
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by LinkMTech View Post
    Big difference between trying to 'read and understand the information'...and not having done squat to help yourself.
    Hey, I'm a choad like the rest of the shmucks around here, I know, they know it...Dig it...
    I just might be able to draw a bit of a conclusion there...Ya think?
    Scowl? No... Roll of the eyes? Maybe... Laughter? Ok, I'll buy that one.
    Too late...
    Guess how I got that much experience?
    There wasn't much for forums back then...
    My two cents.
    Taken...
    Jan 2008
    HELLO...skimask.....i want to ask u some thing....your post 2 the programme i can use it...if i want the temperature reach to 60oC and on alarm so wat the comment should i wirte it...the comment is like if portc.6=60oC then portd =1 rite or not.............if cant can u write down and example for me see it....
    thanks u so much
    skimask's Avatar
    skimask Guest
    thanks u so much
    Sure...I'll be right over there to write the code for you.
    I'll even bring my whole setup...PC, keyboard, mouse, all my books...heck, I'll even bring over working hardware and donate it ALL to you...
    Just for you...
    I'll even bring the beer and some refreshments and a couple of DVDs, a big screen TV and a surround sound system to help pass the time...
    Jan 2008
    hello....skimask........no need say like that ok......if i can done well at picbaisc pro i no need come here to ask u ad....so this is my last question ad...so help me last time ok pls....
    at post 12.....i really duno i try many time ad still cant working....
    i want the temperature reach to high oC around 60 to 100oC will go to on the alarm at port D after lcd will show out temperature is too Hot.....that all....
    hope skimask can help me....pls.............i really duno......pls............
    skimask's Avatar
    skimask Guest
    I'll be right over...
    Super swell good and dandy fine ok then?
    Jan 2008
    hello skimask....sorry to disturb u again....my last part progrme on the alarm u help me write over ad mah..........i very urgent need that part if i not i will die.....it and help me......pls...help ppl god also will protect u and give u every day good luck for u.......thannks u very much......!!!!!
    skimask's Avatar
    skimask Guest
    A cry for help?
    What?
    Jan 2008
    Hello....i Really Want To Cry Ad....i Hope Some One Can Help...it Only The Last One Commnet.......for My Temperature.........help//help///help///!!!!
    Jan 2008
    HELLO skimask your post 2 source code...i can use in the my hardware part now i facing the problme is the temperature sensor no stable...i using the voltage divide rule to give the input on port A.0 rite...and when i start running the temperature will going to high to 255oC and why no stable same time i not use the sensor to burn on fire the value will automative increase or decrease and now i knw how to on the alarm on the portd ad...i try whole night and get the result ad....thanks....and who can let me kwn why the temperature sensor on this source code cant working stable and who can give me ideal or commnet....!
    thanks....!
    skimask's Avatar
    skimask Guest
    thanks....!
    Know what a 4-20mA current loop is?
    Jan 2008
    yup i know 4-20mA.....so wat should i do it now.....need to change the sensor or jst adding the resistor.......wat valuse of the resistor i need to change it....
    skimask's Avatar
    skimask Guest
    You send me the board your prototype is sitting on, and I'll GIVE you the resistor you need.
    Ever heard of a DS1820 or it's derivatives?
    Jan 2008
    now i using the voltage divider rule and the resister i will 18ohm and the test cricuit i will post at below and i got hear that D1820 that is digital temperature sensor...but i duno how to use it...i no use that before....and now how to make the sensor become stable.......
    on the pict the blue colour is my temperature sensor....
    and the resistor value is 18ohm
    and the red colour wire i connet to ADC on port A.0
    and the whole the circuit i also post at here ad...i hope u can help me....
    if really want to change the sensor D1820 the circuit how it look like and where can get it and the programe need to write again or not need...!
    Hi slimpeng,
    Here! Already written, and links to where to get it. You will be here 2 years from now trying to accomplish your goal with that thermistor. Oh, and please do try to use Google, it really does work to bring you good things, like data sheets, vendors, etc. . .
    http://www.maxim-ic.com/quick_view2.cfm/qv_pk/2815/t/al
    @MyConfig = _HS_OSC & _WDT_ON & _PWRTE_ON & _LVP_OFF
    @MyConfig = MyConfig & _BODEN_OFF
    @ __config  MyConfig
    ' One-wire temperature for LAB-X1 and DS1820
    Define PIC16F877A
    @ errorlevel -230
    temperature  Var	Word			' Temperature storage
    count_remain Var    Byte	 	    ' Count remaining
    count_per_c  Var	Byte			' Count per degree C
    DQ	Var	PORTC.0			' One-wire data pin
    define OSC 20
    TrisA = %00000000
    TrisB = %11111111
    DEFINE LCD_DREG PORTA
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTA
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EREG PORTA
    DEFINE LCD_EBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 4
    DEFINE LCD_COMMANDUS 2000	 'Define delay time between sending LCD commands
    DEFINE LCD_DATAUS 50	     'Define delay time between data sent.
      CMCON  = 7
    	ADCON1 = 7			' Set PORTA and PORTE to digital
    	Low PORTE.2			' LCD R/W line low (W)
    LCDOUT 254,1,"initializing"
    mainloop: OWOut DQ, 1, [$CC, $44]       ' Start temperature conversion
    waitloop: OWIn DQ, 4, [count_remain]	' Check for still busy converting
    	If count_remain = 0 Then waitloop
    	OWOut DQ, 1, [$CC, $BE]		' Read the temperature
            OWIn DQ, 0, [temperature.LOWBYTE, temperature.HIGHBYTE, Skip 4, count_remain, count_per_c]
    	' Calculate temperature in degrees C to 2 decimal places (not valid for negative temperature)
    	temperature = (((temperature >> 1) * 100) - 25) + (((count_per_c - count_remain) * 100) / count_per_c)
    	Lcdout $fe, 1, DEC (temperature / 100), ".", DEC2 temperature, " C"
    	' Calculate temperature in degrees F to 2 decimal places (not valid for negative temperature)
    	temperature = (temperature */ 461) + 3200
    	Lcdout $fe, $c0, DEC (temperature / 100), ".", DEC2 temperature, " F"
            Pause 1000                      ' Display about once a second
    	Goto mainloop			' Do it forever
    skimask's Avatar
    skimask Guest
    Datasheets?
    Google?
    Search the forum?
    I'm done and out...Too much time used up already...not enough legwork at the other end.
    The items referred to in Post #6 have run out.
    Jan 2008
    last question....why the temperature going to high....oC and my LCD cant display any oC when going to low oC the LCD can display bck the value....why...! is my progrme problme...or what happen who can let me knw below is my new programe....!!!!
    help to check it
    '* Name : UNTITLED.BAS *
    '* Date : 1/23/2008 *
    '* Version : 1.0 *
    '* Notes : *
    Define LCD_DREG PORTB
    Define LCD_DBIT 4
    Define LCD_RSREG PORTB
    Define LCD_RSBIT 0
    Define LCD_EREG PORTB
    Define LCD_EBIT 1
    ' Define ADCIN parameters '
    Define ADC_BITS 8 ' Set number of bits in result
    TRISB=%11111111
    pause 2
    pause 3
    LCDOUT 254,1,"MY STARTING"
    LCDOUT 254,192,2,2,2,2,2,"TEMPERATURE"
    B0 var byte ' Create TEMPERATURE to store result
    TRISC.6=0
    ADCON1 =%00001010 ' Set PORTA analog
    Low PORTB.2 ' LCD R/W line low (W)
    Pause 1000
    loop:
    ADCIN 0,B0 ' Read channel 0 to adval
    Lcdout $fe, 1 ' Clear LCD
    Lcdout "Value: ",DEC B0,"'C" ' Display the decimal value
    serout portc.6,n2400,[#b0]
    Pause 5000 ' Wait .5 second
    Goto loop ' Do it forever
  1. Data Programming Error at 0000
    By cpatnoi in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 03:37
  2. Problems programming
    By Lionheart in forum General
    Last Post: - 7th December 2008, 16:51
  3. PIC programming algorithm - where is it to find?
    Last Post: - 24th June 2007, 18:31
  4. Some questions for programming
    By fnovau in forum mel PIC BASIC Pro
    Last Post: - 5th July 2006, 16:04
  5. MELab Programming
    By tarr in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2006, 13:36
