Using a wheel-mouse sensor as a motor speed sensor.
Results 1 to 7 of 7
    Sep 2006
    Reading, UK
    Default Using a wheel-mouse sensor as a motor speed sensor.
    Hello,
    I'm trying to use a wheel mouse optical sensor as a quadrature encoder for a small DC motor. I have the small patterned disc from the mouse epoxied onto the back of the motor, and the led/sensor pair positioned as close as I can get it to the original positioning in the mouse.
    At the moment I have two test programs, one which uses the interrupt-on-change feature on my 164876a to increment one of two counters (one for each output from the sensor) when one of the outputs (plugged into b4 and b5) from the sensor changes state. In my main program loop I periodically send the values of the two counters to my pc via serial, then reset the counter. The other version of the program does exactly the same thing, but polls the port instead of using the port b interrupt. Right now I'm just taking these two values as an indication of speed, not worrying about decoding the quadrature signal.
    All this works at low speeds fine, but as the motor gets above what I'd guess is 8000rpm I start getting erratic results -- apparently random results jumping all over the place, even as the motor speed remains steady.
    My instinct is that this is due to some kind of noise in the output from the sensors. One of the websites I've been reading on this subject - http://www.boondog.com/tutorials/mou...kBeforeWeb.htm - uses a hex inverter in between the sensor and and pic, although the author (as far as I can see) doesn't say why. Nonetheless I've tried hooking up my sensors in the same way, and have observed an apparent improvement. I am still getting the erratic results, however.
    Does anyone have any idea how I might proceed? I've tried to keep this brief, but if anyone wants more information (schematics etc), please say and I will try to provide it.
    Any suggestions are appreciated!
    Luke
    Yes we want to see everything. Code, schematic etc etc etc
    Hello Luke,
    Is it possible you are trying to read more pulses than the PIC can keep up with? What is your OSC speed? The wheel I counted had 36 slots . . . 36 * 8,000 = 288,000. Maybe the pulse width is too narrow at high RPM? Also try keeping the sensor in the dark so ambiant light does not weaken your pulse and 60 HZ does not affect it. The 7414 hex inverter has schmitt trigger inputs, probably why they used it.
    Sep 2006
    Reading, UK
    I think you may be right. Here's a listing of my polling version of the code:
    Device 16F876a
    Config WDT_OFF,CPD_OFF,CP_OFF, LVP_OFF, BODEN_OFF, HS_OSC
    Xtal = 20
    HSERIAL_BAUD = 57600							   ' Set baud rate to 9600
    HSERIAL_RCSTA = %10010000       ' Enable serial port and continuous receive
    HSERIAL_TXSTA = %00100100       ' Enable transmit and asynchronous mode
    HSERIAL_CLEAR = ON		' Enable Error clearing on received characters
    dim lastsens1   as byte
    dim lastsens2   as byte
    dim sens1Tcks   as word
    dim sens2Tcks   as word
    dim i           as word
    'CMCON = 7
    TRISB = %11111111
    trisc = %00000000
    gosub flashled
    hserout [$0D, $0A, "Polling speed test"]
    sens1Tcks=0
    sens2Tcks=0
    lastsens1=0
    lastsens2=0
    i=0
    while 1=1
    	if portb.4 <> lastsens1 then
    	    inc sens1Tcks
    	    lastsens1=portb.4
    	if portb.5 <> lastsens2 then
    	   inc sens2Tcks
    	   lastsens2=portb.5
    	inc i
    	if i = 10000 then
    	   hserout [$0D, $0A, #sens1Tcks, "    ", #sens2Tcks]
    	   sens1Tcks=0
    	   sens2Tcks=0
    	   i=0
    wend
    flashled:
    	dim lp
    	lp=0
    	for lp = 0 to 10 step 1
    		portc.5=1
    		delayms 30
    		portc.5=0
    		delayms 30
    	next
    I ran this code for 4s and counted 69 outputs on my terminal program. So I reckon that works out
    10000 x 69 /4 cycles per second = 172500 cycles per second
    The motor specs say the output does 221 rpm at 7.2V through a 75:1 gearbox. I'm giving it 4.8V right now, so that's
    221x75x4.8/7.2 rpm = 11050rpm (motor shaft) *MADE A MISTAKE HERE - SEE POST BELOW*
    ~40 spokes on encoder wheel. Two ‘transitions’ per spoke, so 80 changes in state per revolution. So
    80 x 11050 = 884000 events per second (per sensor)!
    Which if I've done my sums right (admittedly, a big assumption) is considerably more that I can measure.
    I'm going to draw up a schematic of the hardware setup and post it shortly.
    Last edited by lsteele; - 11th December 2007 at 13:54. Reason: mistake in calculations
    Sep 2006
    Reading, UK
    Sorry, I forgot to divide rpm by 60 to get revolutions per second.
    Here is (I hope) the correct calculation:
    motor shaft is running at 11050rpm
    That's 184.17 rotations per second
    40 spokes, which I have to measure on and off, so 80 transitions per second.
    80 x 184.17 = 14733 changes in state per second.
    I think.
    Which seems perfectly measurable. Or am I wrong...?
    In a world of german electrons
    Something completely different. I love those:
    Quote Originally Posted by lsteele View Post
    while 1=1
    I am using them by myself on a regular basis - no irony.
    Be well - whoever you are.
    Jul 2007
    Thumbs up Pic18fxx31
    Did you consider using PIC18F2431/4431? They have a built-in motion feedback module that includes a quadrature encoder interface and noise filters. Works great!
    J-P
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 23:42
  2. MicroCode Studio & the wheel mouse :)
    By nquere in forum General
    Last Post: - 1st November 2009, 03:06
  3. PICBASIC PRO-coding for wireless sensor node
    By syazila in forum mel PIC BASIC Pro
    Last Post: - 10th February 2009, 01:05
  4. Wheel speed sensor
    By Wax-um in forum mel PIC BASIC Pro
    Last Post: - 24th January 2009, 02:07
  5. Using the optical sensor from a ball mouse
    By lsteele in forum General
    Last Post: - 5th September 2007, 17:45
