ADC problem :(
Results 1 to 12 of 12
Thread: ADC problem :(
    Sep 2007
    Default ADC problem :(
    Hi again every one :P
    I have a problem i want the LCD to show 0 to 255 and not 255 to 0. In other words when the pot is on left side ( lowest ohm) it will show 0 on lcd and when its on highest it show 255 on screen. Right now it do the other way.
    Here is the code any suggestions?
    '*  Notice  : Copyright (c) 2007 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 2007-11-30                                        *
    Define	LOADER_USED	1
    Define  LCD_DREG        PORTD
    Define  LCD_DBIT        4
    Define  LCD_RSREG       PORTE
    Define  LCD_RSBIT       0
    Define  LCD_EREG        PORTE
    Define  LCD_EBIT        1
    ' Define ADCIN parameters
    Define	ADC_BITS	   8	' Set number of bits in result
    Define	ADC_CLOCK	   3	' Set clock source (3=rc)
    Define	ADC_SAMPLEUS  50	' Set sampling time in uS
    ad1	var	byte
    ad2 var	byte	    ' Create adval to store result
    ad3	var	byte
    ad4 Var Byte
       TRISA = :%11111111	' Set PORTA to all input
       ADCON1 = %00000010	' Set PORTA analog
       Low PORTE.2		    ' LCD R/W line low (W)
       'Pause 500		    ' Wait .5 second
       ADCIN 0, ad1		        ' Read channel 0 to adval
       ADCIN 1, ad2		        ' Read channel 1 to adval
       ADCIN 3, ad3 	        ' Read channel 3 to adval
       PWM portc.4 ,ad1,1' Send a 50% duty cycle PWM signal out Pin7 for 100 cycles
       PWM portc.5 ,ad2,1' Send a 50% duty cycle PWM signal out Pin7 for 100 cycles
       LCDout $fe, 1
       LCDOUT "nacke:", #ad1
       LCDOUT $FE, $C0, "rygg:", #ad2
    Symbol delay = ad4  ' use b0 as the delay variable
    delay = ad2         ' set the delay to 25 ms
    loop: high portD.0              ' turn on Q1
          pause ad4         ' wait 25 ms
          low portD.0               ' turn off Q1
          high portD.1              ' turn on Q2
          low portD.1               ' turn off Q2
          high portD.2              ' turn on Q3
          low portD.2               ' turn off Q3
          high portD.3              ' turn on Q4
          low portD.3               ' turn off Q4
       Goto    main        ' Do it forever
    Kaldurenik, If all you want to do is reverse the way it is displayed then just say:
    LCDOUT "nacke:", #(~ad1)
    As long as ad1 is a byte variable it will work.
    Sep 2007
    ok thanks i will try it in a moment and post a update then.
    Sep 2007
    nope that did not work now when i change the pot left or right it dont work and! i get 65280 on the screen instead...
    ad1=255-ad1
    Question the "hard" solution ...
    May be I'm simple minded ...
    but crossing the 2 extreme taps wires of the pot might solve the problem ... as it seems Vref is 5v ...
    Did I miss something ???
    yup, as long the OP didn't asked for a software solution and can do some hardware mods, unless you can't be wrong.
    PS: 30cm de neige ici aujourd'hui
    Talking I was waiting for you ...
    Hi, Steve
    For once, you have the "soft" solution ... keep on that way ....( no more guns, ... etc,etc )
    Lots of LOL from le " maudit Français"
    Ici, c'est Water: l'eau ...
    Sep 2007
    well ad1 = 255 - ad1 make the pot "freeze" (not change number)
    Any way we will try that the solution you posted before did work with the ~ but it increased to 1111111111111111 in bin. :O in other word 655xx or something like that.
    Kaldurenik, I don't know how that can be? You have ad1,ad2,ad3,ad4 declared as byte variables unless you have changed them..... Using ad1 = ~ad1 if the variable is a byte should work.
    Sep 2007
    Okey the code look like this now:
    Define  LCD_DBIT        8
    Define  LCD_RSBIT       0
    Define  LCD_EBIT        1
    ad1	var	BYTE
    ad2 var	BYTE	    ' Create adval to store result
    ad3	var	BYTE
    ad4 Var BYTE
       TRISA = %11111111	' Set PORTA to all input
      ' ADCIN 3, ad3 	        ' Read channel 3 to adval
       ad1 = ~ad1
    ad2 = ~ad2
       LCDout $fe, 1
       ad4 = ad2
    The problem is that its "slow" to update on the screen now. its no "smooth" jumps its like 5-15-70-100
    (its 0 to 255)
    ofc its all about how fast i move it.
    but maybe the fastest way is just to turn it around ye?
    Sep 2007
    Ok i solved it thanks every one! The
    ad1 = ~ad1
    ad2 = ~ad2
    helped alot
    Thanks again!
  1. pic12f675 ADC problem
    By radu022003 in forum mel PIC BASIC
    Last Post: - 1st September 2009, 11:13
  2. PIC18F2423, ADC problem
    By mistergh in forum mel PIC BASIC Pro
    Last Post: - 17th March 2009, 02:31
  3. Mutliple ADC problem with PIC16F877
    By andyto in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2007, 18:47
  4. ADC problem with PIC16F917
    By eetech in forum mel PIC BASIC Pro
    Last Post: - 7th March 2007, 22:22
  5. Problem reading multiple ADC ports
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 4th November 2004, 17:46
