Compactflash libraries translation
Results 1 to 7 of 7
    Moldava's Avatar
    Moldava Guest
    Default Compactflash libraries translation
    Hello,
    i fond some compact flash card libraries for avr bascom here:
    they are written in avr assembler,and they donīt look that complicated...i wonder if someone here wants to collaborate for translating this and share them for the developement of pbp...i will work too,my weak point is that i donīt know avr assembler,i'm trying to learn the basics just for this task...
    Believe me that these are really useful...i've been playing with the demo of mikrobasic,i builty an small adapter board for connecting CF to pic,and i'mn impressed with the results...but i want to use this inside PBP...
    http://www.mcselec.com/an_123.htm
    the link to the original article
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Moldava's Avatar
    Moldava Guest
    mmmm...i could not find any information about compactflash on that link...only mmc and sd....
    Have you seen this..?
    http://www.mikroelektronika.co.yu/en...t/tools/cf.htm
    You mentioned you have experimented with the mikroBasic compiler examples. Just curious if you were aware they offered "PIC " source code examples with this CF reader.
    Seems worth the meager $18.00 for the CF reader + source code, and it sure would be easier to convert over to PBP than AVR assembler.
    -Bruce
    tech at rentron.com
    Moldava's Avatar
    Moldava Guest
    yes,in fact those examples are also included in the demo of mikrobasic,and i based my experiments on them...the board was not necessary,because i already had the cf connectors,and i only had to build an small adapter board....
    The problem i fouynd with their routines is that the initialization is somehow slow,so i think that in assembler that would work better....assembler examples for pic are these:
    So,thanks for your reply Bruce,and i hope that we can add this to PBP...
    I'm ordering one of the Easy PIC 2 USB programmer/dev boards shortly for evaluation. I'll get the CF card add-on board too, and have a look at converting or adding the .asm CF code example into PBP.
    -Bruce
    tech at rentron.com
    Moldava's Avatar
    Moldava Guest
    Here they are:
  1. Replies: 1
    Last Post: - 22nd June 2007, 00:57
  2. Translation Problem
    By cyh_fax in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2007, 14:11
  3. Protel Libraries.
    By muddy0409 in forum Schematics
    Last Post: - 15th August 2005, 14:27
