Seeting array variables in For-Next loop
Results 1 to 6 of 6
    Feb 2003
    Sydney, Australia
    Default Seeting array variables in For-Next loop
    Hi Guys,
    I have a problem with is probably Sunday morning foggy head, but I cannot remember for the life of me how to assign values to an array. What I want to do is load up a 65 byte array with 0s that will then be changes based on a RS232 command that comes in.
    The issues I have is with trying to assign values as part of a for-next loop:
    <code>
    ch[64] var byte
    for x = 0 to 63
    ch[x] = 0
    next
    </code>
    This gives me a compile error, as does ch(x) = 0.
    I have checked the manual and tried searching the forums, but can find nothing useful.
    Help !!
    bill.
    sinoteq's Avatar
    sinoteq Guest
    Default Take a look at...
    http://www.picbasic.co.uk/forum/show...ighlight=array
    There are lots of tips and tricks there. It's under the FAQ section.
    Feb 2003
    Sydney, Australia
    I saw that, but it is only seems relevant if you want to pull a bit out of a byte array.
    What I want to do is pull a byte out of a byte array, but I cannot find the syntax to say 'assign this value to value X of the array'
    Or am I looking straight at the solution without seeing it??
    bill.
    Feb 2003
    Salt Lake City, Utah USA
    No: ch[64] var byte
    Yes: ch var byte[64]
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Feb 2003
    Sydney, Australia
    Update :
    This seems to let me define the blank array, although due to other issues I cannot compile it and test it. I am assuming that the fact I no longer get an error on that line means it will work.
    <code>
    for x = 1 to 64
    <tab>ch0[x] = 0
    next
    </code>
    I am now having issues getting single values into or out of the array. AM I DOING SOMETHING STUPID????
    ch[1] = 255
    will compile with a message 'ERROR: Redefinition of LABEL ch'
    I am also trying to send a byte from the array out the HSEROUT command. I have tried :
    HSEROUT[ch[2]]
    but get a message about it being a Bad Expression.
    Please help !!
    bill.
    Feb 2003
    Sydney, Australia
    Paul,
    I just saw your post after I hit submit on the post I just completed.
    Thank you for that. I can stop pulling out the hair I have left.
    I knew I must have been doing something really stupid!!
    Thanks again,
    bill.
  1. Simple Array Demo
    By Archangel in forum Code Examples
    Last Post: - 15th February 2010, 04:46
  2. Controlsystem for compact sporting (clay shooting)
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 30th July 2009, 16:48
  3. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 05:02
  4. Serial Relays
    By tazntex in forum General
    Last Post: - 17th May 2007, 17:42
  5. Reading Array values into variables
    Last Post: - 21st March 2005, 10:30
