Ethernet <> PIC link
Results 1 to 10 of 10
    Jun 2007
    Mansfield, UK
    Default Ethernet <> PIC link
    Hi, Is it possible to connect a PIC chip to an ethernet socket? If so how, and does anyone know how to send the data using VB?
    brighton
    Yap i think its possible depends on what you want to do
    have a look at this baby
    http://www.ezweblynx.com/
    http://www.digi.com/products/embedde...iconnectme.jsp
    Isaac
    Jun 2007
    Mansfield, UK
    What i really want to do is use it like im using serial now but i can see that in the next year or so im going to need something a lot faster than serial and ethernet seems to be what lighting people use now. Im not going to be sending webpages. It will just be a string of about 1024 bytes. When testing with my serial circuits ive found that anything over 22 bytes is just too slow. 22 bytes will work fine for now but i will need ethernet soon. Possibly even for the next project
    Loveland CO USA
    Default siteplayer
    http://www.siteplayer.com/main_content.htm
    I have a SPKI developer kit. With it my PIC talks RS232 to the SitePlayer who has a web page. Any browser can see the webpage and get/send information.
    SitePlayer also has a Serial Port box that allows sending data over a network from RS232 devices.
    Jun 2007
    Mansfield, UK
    I dont want something that can be accessed by a browser. I just want to send raw binary data. If it has the basic TCP/IP stuff then it will work fine but i dont want the HTTP protocol too. Its not for anything to do with webpages. Its for PC <> Lighting link
    Apr 2003
    Cambridge - UK
    take a look at www.crownhill.co.uk/tibbo
    http://www.crownhill.co.uk/level3.php?cat=24
    Very compact and highly integrated, the EM202 Ethernet module features built-in Ethernet magnetics, RJ45 connector, and even four status LEDs! While being a true one-component Ethernet solution, the EM202 has a board footprint just slightly bigger than that of a regular RJ45 connector. Like all the modules in the range its BASIC programmable.
    Jun 2007
    Mansfield, UK
    That looks good
    The EM1202 looks good too. 4 serial ports. The idea of this circuit is to control lights that are quite far away. That would mean 1 ethernet cable (maby even a wireless adapter plugged in) instead of 4 serial cables.
    Its a little expensive but another idea was to use a PC to accept the ethernet so the price isnt too bad compared to a PC
    Thanx
    I have test the EM202-EV modules. Is just the EM202 on a board with serial adapter chip and SMPS power supply on a small footprint PCB.
    It worked great and fast. I am very pleased with performance though pricey...
    Another solution is to use an old net card from PC and do the control with a PIC. Google and you shall receive!
    Jun 2007
    Mansfield, UK
    You mean i could make a circuit which connects to a PCI card? :O That could be usefull for some many things Ill deffo google that
    Yes exactly that! The ISA cards I think are easier to manage because the pcb has larger pads, but PCI could also be used with a little dexterity.
  1. Adding TCP/IP Ethernet to PIC - how?
    By gtvmarty in forum Ethernet
    Last Post: - 10th December 2010, 19:55
  2. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
  3. PIC 18F97J60 and Ethernet
    By mikebar in forum mel PIC BASIC Pro
    Last Post: - 16th April 2008, 13:51
  4. Ethernet PIC
    By Christopher4187 in forum USB
    Last Post: - 17th July 2006, 05:57
    Last Post: - 12th March 2005, 00:14
